I'm developing on a PC/104 stack which aparently has an I2C interface. However, on further investigation it is actually an SMBus interface but says the two are interchangable up to 400kHz. However, the only way I can access it is through a DLL provided by the vendor. The DLL only has SMBus specific commands but reading up on SMBus I can see that the read_byte functionality seems to be the same as that for I2C.
The DLL shows the interface for read_byte as:
// Call this function to reads a byte on the SMBus. This function
// requires the proper values to be setup in the SMB_REQUEST structure.
// This call is valid after a successful OPEN call has been made.
// Parameters: handle - Handle to open SMBus API
// request - input SMB_REQUEST structure
// Returns: 0=SUCCESS, non-zero = FAIL
SMBUS_API int SmBusReadByte( SMBUS_HANDLE handle, SMB_REQUEST *request );
....defining the SMB_REQUEST struct as
typedef struct _SMB_REQUEST
unsigned char Address;
unsigned char Command;
unsigned char BlockLength;
unsigned char Data[SMB_MAX_DATA_SIZE];
} SMB_REQUEST;
Relating this to I2C I'm thinking that: Address is the address of the I2C device Command is the register to read from BlockLength the amount of bytes to read Data is the memory buffer used to give back the result.
However, using it like this doesn't seem to work. There is also a SmReceiveReadByte() function with the same interface so I'm not sure whether I'm supposed to be using that or this funcion. There is also a SmBusReadWord() function with the same interface so that leads me to beleive that I have the wrong idea about BlockLength above. What else could it be? I'm probably not using this correctly at all. Would anyone be able to shed some light on this for me?
Thanks
