I was wondering if someone knew if there was a way to configure pin swap groups on a library component in Altium, rather than from the schematic, so I didn't have to do it every time I put down a large memory or FPGA.
Thanks!
If you want to enable pin-swapping on a component from the altium libraries that does not have pin swapping already available, you're going to have to edit the library.
Find the built-in library (It'll likely be an *.IntLib
), break it down to a schematic and PCB library (*.SchLib
, *.PcbLib
), and make your changes to the SchLib
. Then, instead of using the assembled IntLib
, you just add the two separate libraries to any project that needs them.
