I am working with testing certain test cases with iverilog with -o option for example
iverilog -o <output file name> <Test bench if required> <verilog file>
I had also read about the other flags like -c -s and others given on this link, but i didn't get any test cases to test them.I am pretty new to verilog.So if any one can provide small test cases for iverlog to check other flags.
    \$\begingroup\$ The manual may answer your questions if you haven't already checked iverilog.wikia.com/wiki/Iverilog_Flags \$\endgroup\$ – travisbartley Jul 8 '13 at 10:05
  • \$\begingroup\$ @trav1s: yes i had already checked that link but didn't find it that much useful.Searching for more. \$\endgroup\$ – shailendra Jul 8 '13 at 10:13
After studying further i found that -c option can be used even for two files i.e. testbench.v and verilog.v.
we just need to create a ".txt" file with the name of the both the files written line after line like this
testbench.v verilog.v
and pass it to iverilog.Further i wasn't able to get any test case with the usability of -s flag, though i tried to use it in followoing case but it gives no result and give wrong .vvp file which after executing produce no .vcd file.
module half_adder(
    output S,C,
input A,B
xor(S,A,B);
and(C,A,B);
endmodule
module full_adder(
    output S,Cout,
    input A,B,Cin
wire s1,c1,c2;
half_adder HA1(s1,c1,A,B);
half_adder HA2(S,c2,s1,Cin);
or OG1(Cout,c1,c2);
endmodule
module ripple_adder_4bit(
    output [3:0] Sum,
    output Cout,
    input [3:0] A,B,
    input Cin
wire c1,c2,c3;
full_adder FA1(Sum[0],c1,A[0],B[0],Cin),
FA2(Sum[1],c2,A[1],B[1],c1),
FA3(Sum[2],c3,A[2],B[2],c2),
FA4(Sum[3],Cout,A[3],B[3],c3);
endmodule
i used -s option with half_adder and as well as with ripple_adder_4bit but in both cases it didn't worked out.Still figuring out their use.
For reference i had used this link
| improve this answer | |
