Altium Copper Pour
As you can see above, I'm trying to make a copper pour connect all the GND nodes.
I could run a track and define its width to be huge (accomplishing the same thing) but I don't really think that's how it is supposed to work. I've tried all the settings (pour on all same nets, etc).
I have turned off ERC and all other layers too, so it shouldn't be a problem with those.
If anyone has some insight, it'd be great. Thanks!
I had a plane design rule (Design >> Rules) giving me a 10 mil clearance on polygon pours. Removed it (for now), it fixed the problem. I'll have to exempt the polygons under these components for that rule. Thanks!
