I'm looking at making a reflow oven and have just found out the toaster oven I have bought uses a standard conduction heating element rather than infra-red. The knob used for temperature control goes up to 250˚C - so should be high enough for the lead-free solder-paste I have access to. Will using a reflow oven with a standard heating element work? Most of the guides I can find on the 'net talk about infra-red versions.
  • \$\begingroup\$ Shouldn't make much difference, but try for about 1500 watts. \$\endgroup\$ Jul 10, 2013 at 11:25
  • \$\begingroup\$ Also, I recommend starting with lead solder, unless there's a regulatory reason to do otherwise. It's much easier to deal with. \$\endgroup\$ Jul 10, 2013 at 12:35
Worked OK for me.
Don't count on that 250C being accurate. I used a PT1k and a microcontroller to get a reasonably accurate temperature profile.
