The issue is likely to be insufficient voltage for the desired operation.
Based on the description, this is the schematic for the circuit being used:
For the current source to function as designed with a 5 Volt supply, the maximum resistance across the terminals of the sensor would have to be under 25 kOhms.
Explanation:
- If the sensor has a resistance of, say, 100 kOhms, then it would require
V = I x R = 10 Volts
across the sensor alone, to allow 100 uA to pass. Add a minimum of 2.5 Volts for operation of the REF200, and the minimum required supply voltage is 12.5 Volts. For stable operation, take 15 Volts as a safe margin.
- If the sensor has a resistance of, say, 22 kOhms, then it will develop just 2.2 Volts across its terminals. This leaves
5 - 2.2 = 2.8 Volts
across the REF200 current source, which is within its recommended operating range of 2.5 - 40 Volts.
- In the schematic shown above, add a supply voltage via a battery, replace the sensor with a potentiometer, and vary the potentiometer to simulate this behavior for yourself.
Thus, depending on what the sensor's effective resistance is, at the desired operating point, the supply voltage for the current source to provide a stable 100 uA may need to be higher than the 5 Volts provided.
