-1
i am in second year of mechanical engineering and i want to learn about embedded systems and to program them.from where should i start? which books to refer? is it possible to learn it without any coaching? I have completed my c programming course.
closed as too broad by JYelton, Nick Alexeev, clabacchio Jul 10 '13 at 17:43
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ you are a mechanical engineer why you want to build embedded design. But if you really want, then you can go for Mazidi books for 8051, AVR & PIC controllers \$\endgroup\$ – Aircraft Aug 19 '15 at 8:28
  1. Pick a microcontroller
  2. Google embedded systems and the microcontroller of choice. (There are many that have special book designated for that, but also many that don't)
  3. Look into an evaluation board that'll make your life easier and less time consuming to start the project
Maybe Try sparkfun
There are many good microcontrollers to start with
and much else
