I'm designing a board which uses an LDO that comes in the SOT23-5 package. I have these parts in my possession, and on the part label (from Digikey) it displays that it is a SOT23-5, which makes sense. However, the part datasheet lists it as a SOT23-5 L, and I can't find any documentation on the difference between the "standard" package and the L suffix. I'm thinking that the L might be for low profile, like in LQFP packages, but for all I know, there isn't any difference, and it's just a manufacturer anomaly.
I'm only concerned because in Altium, it appears that there are two distinct footprints for the two. Is the "L" just the same size package with larger pads (in Altium), or is there some other minute difference between the two?
This is the part I'm using, and here is the datasheet.
