I am trying to make some Arduino code count on a 7 segment display. I have the wiring all right but this code will not delay one second and go to next function. Any ideas?
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
void setup() {
  // initialize the digital pin as an output.
  // Pin 13 has an LED connected on most Arduino boards:
  pinMode(3,OUTPUT);    pinMode(4,OUTPUT);    pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);    pinMode(7,OUTPUT);    pinMode(8,OUTPUT);
  pinMode(9,OUTPUT);
void n0() {
  digitalWrite(3,LOW);  digitalWrite(4,LOW);  digitalWrite(5,LOW);
  digitalWrite(6,LOW);  digitalWrite(7,LOW);  digitalWrite(8,LOW);
  digitalWrite(9,HIGH);
void ndash() {
  digitalWrite(3,HIGH); digitalWrite(4,HIGH); digitalWrite(5,HIGH);
  digitalWrite(6,HIGH); digitalWrite(7,HIGH); digitalWrite(8,HIGH);
  digitalWrite(9,LOW);
void loop() {
  n0();
  delay(1000);
  ndash();
If I understand your symptoms correctly, you need a second delay.
Here's what the code looks like if you executed the loop a few times:
  n0();
  delay(1000);
  ndash();
  n0();
  delay(1000);
  ndash();
  n0();
  delay(1000);
  ndash();
  n0();
  delay(1000);
  ndash();
ndash() is only displayed for however long it takes for n0() to execute, which is probably too fast to see.
    \$\begingroup\$ The underlying C in Arduino is basically this: int main() {setup(); for(;;) {loop();}} \$\endgroup\$
    – Nick T
    Commented Dec 6, 2010 at 7:23
