I am working with TI's CC2540 SoC using CC2540dk-mini. My software stack is:
  • Ubuntu 12.04
  • sdcc Compiler
  • cc-tool to flash programs onto board using cc-debugger
I can compile, build and flash firmwares perfectly (until now) using these tools. But I do not know how to debug (toggle breakpoints, see sfr values, etc.) or even to "print" from CC2540.
Chapter 3 from CC2540 user guide talks about the debug interface, and reading it I notice that flash programming is done using this interface. So... aparently to debug the firmware I would have to extend cc-tool. It sounds right?
About printing: reading the sdcc user guide (section 3.17.2.1) I realize that I have to provide putchar() function, which makes sense. But what low level protocol should I use? USART? Or something else? (debug interface?) How the CC2540 can talk with cc-debugger? How cc-debugger can talk with Ubuntu?
This all seems a little vague, but it is because I have no experience in this "field" (I always used Arduino and I never had to go in this "low level" before).
  • \$\begingroup\$ With Arduino, you are adapting a runtime communication scheme (serial over USB) to briefly talk to a bootloader on the chip. In contrast, the CC debugger talks to dedicated logic in the chip, and isn't really intended for runtime communication from a user program. There may be a specific secondary capability built into it for that. Or if not, you may be able to create a communication channel by having the debugger monitor mailbox variables for information from the program, and then set a flag to let the program know the message has been collected and can be overwritten by a new one. \$\endgroup\$ May 6, 2014 at 17:21
  • \$\begingroup\$ Why not use Code composer studio?? You get a free license with you dev kit (see here processors.wiki.ti.com/index.php/Licensing_-_CCS), they have a version that runs in linux. Using the full IDE will take away the complexity of setting up your debug environment. As to putchar() the communication interface is your choice, I doubt that you can use the debbuger interface but pretty much take your pick from the available communication interfaces in you micro. \$\endgroup\$
    – Kvegaoro
    Jun 8, 2015 at 20:24
I assume you are using code composer and you should(Keil uvision is a other good option). When you must select in the Flash button's arrow the "debug" option(little insect icon).
Than when you are going to Flash your MCU a interface will open showing the register and where you can track variable values.
Regards, MathieuL.
