What does this symbol mean? It's part number is XM## and is connected in series with the output voltage of a chip.
  • 4
    \$\begingroup\$ I've only ever seen that used for a jumper. What does it physically look like? \$\endgroup\$ Jul 15, 2013 at 2:20
  • \$\begingroup\$ On the layout file it is physically merged with the chip. I don't have the chip itself readily available unfortunately. \$\endgroup\$
    – Drew
    Jul 15, 2013 at 2:56
  • \$\begingroup\$ A colleague has confirmed that its a jumper, that can be removed to measure amperage/power. \$\endgroup\$
    – Drew
    Jul 15, 2013 at 2:58
    \$\begingroup\$ @Drew you can answer your own question. \$\endgroup\$
    – Phil Frost
    Jul 15, 2013 at 11:52
This is a jumper. In this case, it is used to remove so that a power/amperage measurement can be made.
