Is there a way in verilog to do the following? I have a variable number of FIFOs (1 to 4) created with a generate statement inside of a module
pseudocode:
module()
    generate( for i to NUM_FIFOS )
        FIFO fifoI( args )
What I want to do is have the read data from these FIFOs as outputs of the entire module. Is there a way to have a variable number of output?
e.g.
module(
    generate for( i = 0 to NUM_FIFOS )
        output FIFO_dataI
Thanks for the help!
Use a parametrized bus width:
module FIFO #(WIDTH=8) (
  output [WIDTH-1:0] out,
   /* other ports */
Then overwrite the parameter when generating the instances.
module top #(NUM_FIFO=4,WIDTH_FIFO=8)(
  output [NUM_FIFO*WITDH_FIFO-1:0] FIFO_data,
   /* other ports */);
/* ... other code ... */
genvar i;
generate
    for(i=0; i<NUM_FIFO; i++) begin : gen_fifo
        FIFO #(.WIDTH(WIDTH_FIFO)) fifoI (
          .out( FIFO_data[i*WIDTH_FIFO +: WIDTH_FIFO] ),
          /* args */ );
    end : gen_fifo
endgenerate
endmodule : top
    \$\begingroup\$ This is the right answer, but its also worth noting that a define statement can be used as well. I prefer to use parameter when the constant is used in only the local file and I use define when the constant spans multiple files. But it is up to the designer's discretion. \$\endgroup\$ Jul 16, 2013 at 2:30
  • \$\begingroup\$ Thanks for the answer. Are generates synthesizable, though? \$\endgroup\$
    – ballaw
    Jul 16, 2013 at 5:39
  • \$\begingroup\$ @ballaw, generate statements are generally synthesizeable. \$\endgroup\$ Jul 16, 2013 at 7:14
