Is there any material/device invented to quickly connect SOIC-14 like integrated circuits to, eg, breadboard? I am aware of adapter boards, but what if I want something without soldering? (I am not speaking of very high frequencies and too complex SMDs)
For example, if I remember correctly, I saw similar technology used for small LCD displays (where some kind of resin and evenly spaced wires provided very fine connection from the board to the LCD), so I guess, this kind of technique is possible. SOIC 14, in this example, would require two such "wired pillow" connection terminals, which can be mapped to pins and/or wires.
Is there anything like this existing? Or maybe something with similar purpose, but universal enough to be useful with several cases?
UPDATE: There are prototype boards in existence, which make it much easier (and cheaper) to work with SMDs, eg http://www.whitewing.co.uk/protoboard.html . I wish, there were more such boards available for all kinds of SMDs.
UPDATE2: Actually, I have found anything I needed here: http://www.proto-advantage.com/store/ It seems, they have adapters for nearly everything. ZIF sockets, proposed in the answer, are also quite convenient in use.
7
Common practice is to use a ZIF adapter, aka programming socket adapter, test socket, etc, for the relevant IC form factor. For SOIC 16 through 24, for instance, this adapter ($13.99 on eBay) can be used:
ZIF SOIC socket
Such ZIF sockets exist for several standard SMD IC formats.
The resin-like conducting strips used in LCDs are called elastomeric connectors, and are available in various pin pitches:
Elastomer
These can be purchased in long strips and cut up for use on a DIP adapter, but there don't seem to be any such adapters available on the sites I know of.
  • \$\begingroup\$ Thanks, this is exhaustive answer. I can continue with those key words. \$\endgroup\$
    – Roman Susi
    Jul 17, 2013 at 8:03
You are looking for a ZIF socket, sometimes called a programming adapter. Example of a 14 pin SOIC programming adapter.
  • \$\begingroup\$ Discontinued :-( \$\endgroup\$
    – Roman Susi
    Jul 17, 2013 at 8:16
  • \$\begingroup\$ I was providing a hint as to what to look for, not shopping advice, as we are not a shopping advice site. \$\endgroup\$
    – Martin
    Jul 17, 2013 at 8:32
  • \$\begingroup\$ Sure. Thanks. I just got an impression, that these sockets are somehow not manufactured any more. \$\endgroup\$
    – Roman Susi
    Jul 17, 2013 at 8:58
