I know this is probably a stupid question but I am hobbyist and could not find a solution to this problem.
I have a micro-controller that sends a PWM signal to a transistor that lets current flow through a coil in one direction but I want to be able to change the direction the current flows in every time I send a digital output from another pin on the micro-controller. For that I will have to use another transistor that can let current flow in the other direction.
My problem is that I need a way to switch to which transistor the PWM signal is send to by sending a pulse from a another pin. I am guessing that I will need some sort of digital SPDT switch. Is there anything like this any reference to a component or circuit will help.
  • 4
    \$\begingroup\$ The usual way of driving a coil (normally motors) in two directions is called an "H-bridge". Otherwise, you could do it with a few NAND gates.. \$\endgroup\$
    – pjc50
    Jul 17, 2013 at 14:52
A two input H-Bridge made out of 2 NPN inputs, with the motor drive made out of 2 NPN & 2 PNP transistors and 4 diodes.
The specific transistors you use would be rated for your coil, doesn't have to be those specific ones.
You haven't really given a necessary current but you could also search for "analog multiplexers" that are basically just SPXTs
http://www.vishay.com/docs/72308/dg2714.pdf
That's an example.
If you would still like to use your original approach, it sounds like a SPDT relay would work. Here is a datasheet for one I use often.
There is a control pin which allows you to digitally select between one or the other, but since you are using a microcontroller you will have to drive it with a relay driver circuit like this:
(source: comcast.net)
