I use code composer to program the TMS320C31 DSP (through MPSD) to write to the SST39SF010A flash. I can successfully write one byte to any location of the flash by following the "Chip Erase" then "Byte-Program Algorithm" sequences mentioned in the datasheet.
The problem is when I want to write more than one byte in different locations, only the first byte is written and the rest aren't. I added delays between writes but no difference.
What is the cause of this problem? I searched for drivers (Programming algorithms) for this flash but couldn't find!
Update: 21/7/2013
- First:
This is the code we wrote to program the flash:
void main() {
volatile unsigned int * start_flash = (volatile unsigned int *)0x00001000;
volatile unsigned int * end_flash = (volatile unsigned int *)0x0001ffff;
volatile unsigned char * flash_addr1 = (volatile unsigned char *)0x005555;
volatile unsigned char * flash_addr2 = (volatile unsigned char *)0x002aaa;
volatile unsigned char * flash_addr3 = (volatile unsigned char *)0x005555;
volatile unsigned char * flash_addr4 = (volatile unsigned char *)0x010000;
volatile unsigned int x = 0;
// Chip Erase
* flash_addr1 = 0xaa;
* flash_addr2 = 0x55;
* flash_addr1 = 0x80;
* flash_addr1 = 0x10;
// Delay
for(x=0;x<=100000;x++);
// Byte Program
* flash_addr3 = 0xa0;
// Data in the first address
* (start_flash) = 0xba;
// Data in the following address
* (start_flash+1) = 0xab;
while(1);
"BA" is written correctly in the first address but "AB" isn't.
- Second:
We are using an FPGA in the system between the DSP and the Flash (and all other system peripherals). Data and Address of DSP is bypassed through the FPGA to the Flash, and control signals are generated from the FPGA. I think there is no problem in generating the control signals since we are able to write one byte successfully, is that correct?
