If I were to pulse those mini DVD lasers in sequence, assuming that they were all trained on the same target, could I produce temps high enough to be a decent laser cutter? Or do lasers just not work that way.
I think that If I train 40 of those lasers and run them at 1 watt for 1/40th of a second each, I should be able to produce a significant result.
