I need to simulate how signals are reflected based on the source, load and line impedances and how the signal integrity is effected by the spacing between different traces on a board, traces on the same level as well as different layers, traces of single ended and differential nature.
I want to see how the signal waveform is effect by the factors mentioned above through simulations.
Which software can be used to do this? I am sure that all PCB designers have to do this all the time. I want to do this as an exercise to understand this phenomenon and have a better understanding of it.
In fact, if you are designing a digital circuit with clock frequencies below about 50 MHz, you almost never will have to do signal integrity analysis to get a working design. And if you know what you are doing it is possible to design up to 1 or 2 GHz by using "best practices" rather than complex simulations.
I worked in an organization doing 1, 2, and 3 Gb/s designs and never saw a signal integrity tool in use until 2005 or so. (Although full-blown 3-d EM simulation was very occasionally used for very sticky problems)
However as the number of high-speed nets in your design increases, it's not always possible to stick to best practices everywhere, and then a simulation is valuable to indicate how much you can get away with.
In contrast to what another answer said, SPICE and its derivatives are not well suited to this type of simulation. SPICE is designed for lumped-element analysis at the transistor level. In the situation you described you need to simulate a distributed element (a transmission line) and you're unlikely to have a transistor-level model of your source or load. Some SPICE-derived tools might have a signal-integrity tool bolted on, but it isn't typically what they're good at.
Signal itegrity tools generally use higher level models to reduce simulation time when simulating dozens or hundreds of distributed elements. And they can take inputs from IBIS models of the source and load ICs. These are standardized high-level macromodels that don't reveal details of the IC internals that the vendor might not want to share with all its customers.
Although I use Altium regularly I haven't used its signal integrity modelling tools. But from the description, they do seem to be IBIS-based rather than SPICE-like, so would probably work in many cases.
Another well-known tool is HyperLynx from Mentor Graphics. Cadence offers a tool set called Sigrity which I believe is similar but I have never seen or used.
  • \$\begingroup\$ What is the difference between SPICE and IBIS here? as far as I understand, IBIS only models the actual I/O ports while SPICE models things in more detail at transistor level and these models have be slow. Apart from this many vendors may not give out SPICE models owing to their proprietery nature and produce IBIS models that meet an agreed standard. Is my understanding correct? \$\endgroup\$ – quantum231 Jul 22 '13 at 8:07
  • \$\begingroup\$ @quantum231, SPICE usually refers to a particular set of analysis methods that were used in the SPICE program developed at Berkeley in the 1970's. These capabilities didn't historically include transmission line simulations, though that has been added to most SPICE tools over the years. \$\endgroup\$ – The Photon Jul 22 '13 at 15:45
  • \$\begingroup\$ IBIS doesn't actually specify a method of analysis, but a format for describing the i/o capabilities of a chip. But most programs that use IBIS as a data format will focus on transmission line simulation, and might use simplified models to enable simulating very complex transmission line networks. \$\endgroup\$ – The Photon Jul 22 '13 at 15:46
Altium Designer has signal integrity analysis that can help simulate and discover reflection and crosstalk problems. (Video)
Most of the softwares have simulation capabilities. like Orcad, pads, altium,Hspice etc. most of the spice programs can do them. But most of the efficient softwares are costly. if want to just evaluate and learn try spice simulators. one of good free software is Micro-Cap10 http://www.spectrum-soft.com/index.shtm
