I'm attempting get a very basic PWM code to work. However all PWM outputs seem stuck on +5V with no proper PWM output. It works perfectly in the simulator but not on the chip. Any ideas welcome?
    include <P18f4431.INC>
CONFIG     OSC = IRC
CONFIG     FCMEN = OFF
CONFIG     IESO = OFF
CONFIG     PWRTEN = OFF
CONFIG     BOREN = ON
CONFIG     BORV = 20
CONFIG     WDTEN = OFF
CONFIG     WDPS = 1
CONFIG     WINEN = OFF
CONFIG     PWMPIN = OFF
CONFIG     LPOL = LOW
CONFIG     HPOL = LOW
CONFIG     T1OSCMX = OFF
CONFIG     FLTAMX = RC1
CONFIG     SSPMX = RD1
CONFIG     PWM4MX = RB5
CONFIG     EXCLKMX = RC3
CONFIG     MCLRE = ON
CONFIG     CP0 = OFF
CONFIG     CP1 = OFF
CONFIG     CP2 = OFF
CONFIG     CP3 = OFF
CONFIG     CPD = OFF
CONFIG     WRT1 = OFF
CONFIG     WRT2 = OFF
CONFIG     WRT3 = OFF
CONFIG     WRTC = OFF
CONFIG     WRTB = OFF
CONFIG     WRTD = OFF
CONFIG     EBTR0 = OFF
CONFIG     EBTR1 = OFF
CONFIG     EBTR2 = OFF
CONFIG     EBTR3 = OFF
CONFIG     EBTRB = OFF
CONFIG     STVREN = OFF
CONFIG     DEBUG = OFF
CONFIG     CPB = OFF
CONFIG     WRT0 = OFF
CONFIG     LVP = OFF
;***********VARIABLE DEFINITIONS******************
Timer   res 1
Timer2  res 1
; Reset Vector
STARTUP  CODE    0x00           ; processor reset vector
  GOTO    START                   ; go to beginning of program
 ; MAIN PROGRAM
 PROG1 code
START:
;; Initialise PORTB
;  CLRF  PORTB
;  CLRF LATB
;  movlw 0x00
;  movwf TRISB
;movlw 0xff
;movwf PORTB
movlw    b'10111110'
movwf    TRISC
;  bsf  PORTC, 0
movlw    b'11010000'
movwf    TRISD
bcf  PORTD, 0
 ;***********SET UP OSCILLATOR**************
bsf   OSCCON, IRCF0
bsf   OSCCON, IRCF1
bsf   OSCCON, IRCF2
call INIT_PCPWM
;***********MAIN ROUTINE **********************************
;turn on lamp to show power
bsf PORTD, 1
movlw   d'88'
movwf   PDC0L  ;'set the PWM duty cycle
movlw   d'00'
movwf   PDC0H
bcf INTCON, RBIF
bcf INTCON, RBPU
Loop:
  call Delay
  GOTO Loop                         ; loop forever
 ;*********DELAY ROUTINES**********************
Delay
movlw   d'5'
movwf   Timer
movwf   Timer2
Loop2:
  nop
Loop1:
nop
decfsz Timer, f
goto Loop1
decfsz Timer2, f
goto Loop2
return
 ;***********SET UP PWM***********************
INIT_PCPWM
movlw   b'01000000' ; deadtime
movwf   DTCON
movlw   b'00000000'
movwf   PTCON0  ; Postcale 1:1, PWM time base input is Fosc/4
                ; PWM time base mode is free-running for edge-aligned operation
movlw   b'10000000'
movwf   PTCON1  ; Count up, timer on
movlw   d'99'    ;PTPERL and PTPERH are set up for a XX PWM frequency
movwf   PTPERL
movlw   d'00'
movwf   PTPERH
movlw   b'01000000' ;configure PWMCON0
movwf   PWMCON0     ; enable PWM 0 to 5, all PWM I/O pairs set to complimentary
movlw   b'00000000' ;configure PWMCON0
movwf   PWMCON1     ; Special event postscaler set to 1
                ; Special event trigger occurs when time-base is counting upward
                ; Updates from duty cycle and period buffer registers are enabled
                ; Ouput overides via OVDCON are synchronous to the PWM timebase
movlw   b'11111111' ; no output override
movwf   OVDCOND
movlw   b'00000000' ;OVDCONS is configured such that all PWM outputs are 0 on power up
movwf   OVDCONS
movlw   b'10010001' ;FAULT A and B enabled in catastrophic mode
movwf   FLTCONFIG
movlw   0x00    ;SECTCMPL and SEVTCMPH are cleared
movwf   SEVTCMPL
movlw   0x00
movwf   SEVTCMPH
bcf FLTCONFIG, FLTAEN   ; disable fault condition
bcf FLTCONFIG, FLTBEN   ; disable fault condition
bsf PTCON1, PTEN    ; enable the PWM time base
return
  END
not sure but it might have something to do with your ptper value. for example when i calculate your resolution which is ln(Fosc/Fpwm)/ln2 i get 8.64 bits. I believe you want this to be an integer, such as 8 or 10 bits. So if you backsolve to get the correct pwm frequency, you can then get a proper ptper value. once again, not sure if this is the issue, but it might be..
| improve this answer | |
  • \$\begingroup\$ I've changed PTPER to 255 to give an 8 bit resolution but still no joy I'm afraid. \$\endgroup\$ – tommo2000 Jul 22 '13 at 12:19
  • \$\begingroup\$ I have found that the FLTCONFIG register was set up incorrectly and a fault had been enabled. All working fine now, thankyou. \$\endgroup\$ – tommo2000 Jul 24 '13 at 22:35
Probably harmless, but this doesn't look right:
bcf INTCON, RBPU
I think it should be:
bsf INTCON2, RBPU
...or let it default to 1 to disable weak pull ups on PORTB (PWM0/1/2/3/5/4). As it is coded, it may just be turning off the GIE bit (disabling General Interrupts).
The only other thing I see is that you enable the PWM time base (PTEN) by:
movlw   b'10000000'
...and then later enable it again with:
I would have disabled it while setting things up and then enabled it afterwards. But after reading the data sheet I can't see why that would make a difference anyway.
  • \$\begingroup\$ Thanks I just tried these suggestions but they don't seem to help. Although I will implement them as best practice. Interestingly all ports are high so they are not acting in complementary mode. Also if I change the polarity of the configuration bit all ports go low. Some possible clues perhaps? \$\endgroup\$ – tommo2000 Jul 20 '13 at 18:42
  • \$\begingroup\$ It might be a good idea to post a circuit diagram. Have you tied MCLR to +5V (via a 10-40k resistor)? \$\endgroup\$ – aja Jul 21 '13 at 0:27
  • \$\begingroup\$ Unfortunately I don't have enough reputation points to post an image but I am basically driving it using a Pickit 2 device with MCLR tied to 5V via a 10k resistor. I'm using the internal oscillator so I might try using an external one to see if that will make a difference. Although the clock seems to be working as I can get the USART working successfully. \$\endgroup\$ – tommo2000 Jul 22 '13 at 20:51
