According to IPC-7251, IPC-2222 and IPC-2221 standards:
Minimum Hole Size is calculated according to equations below:
Minimum Hole Size = Maximum Lead Diameter + 0.25mm (for Level A of IPC-2222)
Minimum Hole Size = Maximum Lead Diameter + 0.20mm (for Level B of IPC-2222)
Minimum Hole Size = Maximum Lead Diameter + 0.15mm (for Level C of IPC-2222)
note:
Minimum Pad Diameter is calculated according to equations below:
Pad Diameter = Minimum Hole Size + Minimum Annular Ring X 2 + Minimum Fabrication Allowance
Minimum Annular Ring is 0.05mm (50um).
Pad Diameter = Minimum Hole Size + 0.1mm + 0.60mm (for Level A of IPC-2221)
Pad Diameter = Minimum Hole Size + 0.1mm + 0.50mm (for Level B of IPC-2221)
Pad Diameter = Minimum Hole Size + 0.1mm + 0.40mm (for Level C of IPC-2221)
Density Level A is used for General Design Producibility. It is a Preferred Level. Level A is used for the Low component density. In this case, footprint geometry is ‘Maximum’. This method is applied to the most robust producibility.
Density Level B is used for Moderate Design Producibility. It is a Standard Level. Level B conditions are suitable for re?ow, wave, drag or dip soldering. In this case, footprint geometry is ‘Median’. This method provides a robust solder attachment conditions.
Density Level C is used for High Design Producibility. It is a Reduced Level. Level C is used for the High component density. In this case footprint geometry is ‘Minimum’. This method is applied to a hand-held and portable appliances.
