The goal is to drive a 47k load that requires at least 5mA of current. The design is as shown, with FET values matching their part number: enter image description here
An LTSpice simulation (with generic pmos and nmos devices) demonstares that ideally the circuit should behave as follows when V1 is cycled from 0V to 8V:V1 cycled from 0V to 8V
Currently the voltage across the resistor remains at 300V even when the input is 0V. I've exchanged the pmos and it keeps the node at 0V but does not respond to a 5V input from V1.
I'm unsure as to what values R1 and R2 should have, originally they were both 100kOhm, or if there is something damaging the pmos that I have not considered. I haven't worked with such high voltages before and originally this circuit was designed for 5V (with R1=1k and R2=10k).
The P channel FET has a maximum gate-source voltage of +/- 20V so currently with resistor values as shown it will get 50V and die. Maybe a safer bet is the put a 12V zener across R2 to restrict this voltage under changing values of R1 - but don't lower R1 below 100k. 100k needs a 1W5 rated package - 300 x 300 / 100k = 0.9W.
I'd also be tempted to put something like 100 ohms in series with the P channel drain to limit current in case you have the 47k load resistor at some distance from that FET.
  • \$\begingroup\$ R1 can be fixed at 1MEG and R2 can be lowered to 50kOhm (or kept at 200k) with a 12V Zener in parallel. Just to make sure, there shouldn't be enough current to damage the diode with the 1MEG resistor once the nmos is ON. \$\endgroup\$
    – diverges
    Jul 22, 2013 at 15:23
  • \$\begingroup\$ @diverges A 12V 250mW zener ought to have less than 15mA flowing through it. Even if R1 were 100k and directly across the 300V, the current would only be 3mA. It's not a worry. \$\endgroup\$
    Jul 22, 2013 at 15:34
