12
I have been using and making LED flashlights for years now and I am VERY familiar with all of the circuitry and technology inside of them, but I just got my first LED house light bulb that runs off of 110v AC electricity. It is very similar to a flashlight - it has a large heatsink, and 1 or more LEDs inside of it (brand and specs of emitters, I do not know). The part that I am most curious about is how the electricity from the socket gets to the emitter. In a flashlight the power comes from a DC battery through a current regulator (LED driver) and into the LED itself. This is not difficult because the voltage of common LED emitters is about the same voltage as Lithium batteries (3.7v, 7.4v, etc) which makes the current limiting relatively simple coming from a one or two cell light.
How does this work for a high voltage AC bulb? Is there a transformer and rectifier inside of EVERY bulb (I sure hope not), or are the emitters manufactured to run off of 110v AC power and just use half of the wave cycle?
  • \$\begingroup\$ The reality is closer to halfway between what you're saying. They are more like switching AC/DC converters. Not a large, bulky transformer but it is definitely complicated electronics inside of there. You have a full suite of power conversion and power sensing circuitry in each bulb. \$\endgroup\$
    – scld
    Jul 24, 2013 at 17:16
  • \$\begingroup\$ Ohh, I forgot about switching power supplies (I've never used/made one personally), but I am familiar with them. That makes more sense than a transformer... but still seems very inefficient and bulky. \$\endgroup\$
    – Sponge Bob
    Jul 24, 2013 at 17:21
    \$\begingroup\$ @KeeganMcCarthy Au contraire, switching supplies are highly efficient and tiny. \$\endgroup\$
    – Passerby
    Jul 24, 2013 at 18:03
    \$\begingroup\$ They can even put entire 1A switching regulators in a single (large) 24-pin IC. \$\endgroup\$ Jul 24, 2013 at 18:17
  • \$\begingroup\$ @IgnacioVazquez-Abrams I believe that is how the little cube-like iPhone chargers operate. \$\endgroup\$
    – Sponge Bob
    Jul 24, 2013 at 19:47
13
There are several circuits on the internet from noatable sources that show how LEDs can be powered directly from an AC supply without a transformer. Here's one from ON semi: -
And here is the document it came from. The document is entitled "High Current LED - capacitive drop drive application note".
Here is another interesting article, this time from EDN. It shows the following diagram, again transformerless: -
And another article and circuit here: -
  • \$\begingroup\$ It's a very useful post. You introduce all off available solution for mains led led drivers. I really appropriate it. \$\endgroup\$
    – MSS
    Apr 17, 2019 at 15:21
6
Depends on the led light bulb. Some are direct dc bulbs. These are meant for 12v lamps, not AC lamps. These are smaller, lack the ac rectifying parts, normally set up with 3 leds + resistor or small current controlled ic, in a ceramic casing.
Now LED bulbs that are meant to be replacements for standard 120v incandescent bulbs are very similar to CCFL bulbs. They have AC rectifying section, most are half wave. Then they step it down, then use a current control section to provide the final step for the lighting. If it is a Fading led bulb, there would be more circuitry inside for that.
  • \$\begingroup\$ Uncommented downvote, yay? \$\endgroup\$
    – Passerby
    Jul 24, 2013 at 18:41
    \$\begingroup\$ Thanks for the answer and photos, but they don't really answer what happens to the electricity between the wall and the emitter. PS. I wasn't the person who downvoted an hour ago. \$\endgroup\$
    – Sponge Bob
    Jul 24, 2013 at 19:56
