I am trying to make a power source to feed the following:
- 3x DC motors, that need to work under changeable voltage; not supposed to operate over 2A RS385-ST
- 1x Servomotor 12V not over 1.5A
- 2x 5V 1A for this L293D
- 1x 9v 0.1A (for control unit)
I am using a LM317 to control the voltage each motor receives; so I am using three of this regulators, one for each motor. The picture shows the circuit. The motor loads are modeled with resistances. Circuit in picture does not include other regulators:
As noted there is also a couple of 7805 for the 5V outs, one 7812 for the 12V servomotor and a 7809 for the control unit's power. They are all part of the 78xx family. All the regulators are connected to the bridge's output.
My problem is that no matter what capacitor I use for smoothing the bridge's output, the simulation fails. I am simulating in Multisim.
I think that my problem is that the input voltage is too high for some of the regulators. All ideas, from changing the circuit to finding a different duty, are welcomed.
