I need to implement the following block.
LD comes from a clocked control input but Adder and Score Register must be built using sequential logic. When control outputs 1, I load my score into Score Register but I don't know how to stop/freeze it because once LD is 1, I will be adding Score Register's output with the BUS, then load and then add it and so on.
How do I make my combinational circuit execute loading only once?
I think your only option is to use an edge triggered register like the 74173. Otherwise the circuit does not reach a stable state as you described.
Use a pulse detector circuit to convert the latch signal into a clock signal.
