21
I am trying to interface a microSD card (2 GB, Kingston, Sandisk) with a Silicon Labs C8051F931 controller.
I am very much confused about the sequence which I have to follow for initialization. In the book SD Card Projects Using the PIC Microcontroller, page 135 mentions:
The steps to switch the SD card into SPI mode should therefore be as follows:
Power-up.
• Send at least 74 clock pulses to the card with CS and Data Outlines set to logic “1.”
• Set CD line low.
• Send 6-byte CMD0 command “40 00 00 00 00 95” to put the card in SPI mode.
• Check R1 response to make sure there are no error bits set.
• Send command CMD1 repeatedly until the “in-idle-state” bit in R1 response is set to “0,”
• and there are no error bits set. The card is now ready for read/write operations.
I tried this, but I am getting 01 even for CDM1. 00 is expected.
Also here I see a different command sequence where he sends CMD8 after CMD0. But the book says I have to send CMD1.
What is the correct sequence?
6 Answers 6
44
Actually, most of the info/code you may find on SD initialization is either dated or innacurate, since it predates SDHC & SDXC by years. The procedure is more complicated nowadays, as it forces you to deal with old hardware in a backwards-compatible way.
Firstly, as mentioned by others, select a low initial clock rate (generally in the 100 kHz - 400 kHz range; use 400 kHz if possible); you'll be able to switch to higher clock later on, if the device allows for it. While new cards can safely withstand MHz-ish clocking, older will complain (i.e. not communicate or return garbage).
Next thing is that you shouldn't use CMD1 to initialize SD/SDHC/SDXC cards unless your card doesn't recognize CMD55/ACMD41; as said in the SD Card specification:
In any of the cases CMD1 is not recommended because it may be difficult for the host to distinguish between MultiMediaCard and SD Memory Card.
Some controllers (newer and higher capacity cards mostly) will simply stay in IDLE if you issue CMD1 to them. You should first issue CMD8 0x1AA after the reset (CMD0), and then try to use CMD55 + ACMD41. If and only if that fails, use CMD1.
tl;dr to initialize the card in SPI mode you should:
  1. CMD0 arg: 0x0, CRC: 0x95 (response: 0x01) - note that in case of 0xFF or garbled response you should simply repeat this step; see below for more info.
  2. CMD8 arg: 0x000001AA, CRC: 0x87 (response: 0x01, followed by echo of arg, in this case 0x000001AA) - while it may seem that this command is optional, it's completely mandatory for newer cards. While 0x1AA is a common arg value here, you may actually pass other values as well; see "Table 7-5: Card Operation for CMD8 in SPI Mode", p. 108 in spec for details.
    3a. CMD55 arg: 0x0, CRC: any, 0x65 actually (response: 0x01; CMD55 being the prefix to every ACMD; if the response is 0x05, you've got an old card - repeat CMD1 with arg 0x0 [CRC 0xF9] instead of CMD55/ACMD41)
    3b. ACMD41 , arg: 0x40000000, CRC: any, 0x77 actually (note that this argument assumes the card is a HCS one, which is usually the case; use 0x0 arg [CRC 0xE5] for older cards). If response is 0x0, you're OK; if it's 0x01, goto 3a; if it's 0x05, see note on it above (in 3a.); if it's neither, something's wrong with it (also see below).
Most cards require steps 3a/3b (or CMD1 for old cards) to be repeated, usually at least once, even if you wait some time between them; i.e. the actual sequence is CMD0/CMD8/CMD55/ACMD41/CMD55/ACMD41 (or CMD0/CMD8/CMD1/CMD1) - to be sure, try the CMD55/ACMD41 (or CMD1 if you got 0x05 from them) \$n\$ times (select \$n\$ within your reason; it's actually quite common to have to wait a couple hundred ms if the device is just after the power on, so aim for that), with small delays between the tries if you wish, and assume fail if response 0 doesn't appear (i.e. if the device stays in IDLE mode for some reason). Also, receiving 0xFF from CMD0 is common if a device was in some "strange" state previously (e.g. hung up, got S̲S̲ deasserted [high], had over-/undervoltage on some pins etc.) - just give it some time, rinse and repeat \$n\$ times. A garbled response to CMD0 is quite OK sometimes - if you sent it a couple of times and the response is still neither 0xFF nor 0x01, try to go forward with CMD8. If it works - you're good to go; if it doesn't - it's probably broken.
Note that responses that have the MSB set but ain't 0xFF usually suggest that your SPI got a shift in clocking (as a result of e.g. Vcc drop, which happens routinely when you're doing SD hotplugs). To fix it, you can try to completely reset the device (power on/off, deassert/assert S̲S̲ etc.); it usually works.
Also, the spec says
After the last SD Memory Card bus transaction, the host is required, to provide 8 (eight) clock cycles for the card to complete the operation before shutting down the clock.
It could work without it, but since 8 cycles = 1 SPI output byte, it won't hurt much and it's just good to have it.
Note that you should assert S̲S̲ (aka CS) low at least before and after each CMD - it's completely mandatory in case of CMD0 (the device won't turn on without it) and, in reality, required for all other CMDs if you have a standards-compliant SD card. Connecting the card's S̲S̲ to GND permanently may seem to be a good idea if the card is the only SPI client your host will ever connect to, as it would save you both the uC output pin & the need to manage it by code at all, and because the card should assume it's selected all of the time. In reality, some cards (if not most of them) actually expect a high-to-low slope to turn on instead of simply detecting low, and thus get angry if you don't toggle the S̲S̲ bit at all, and then either lag clocks or spit garbage; some (usually newer) cards should work, some (older) may not, YMMV (yet again). Still, for any more robust SPI configuration (>1 slave device) remember to assert the pin low before any actual transaction with the given SD card.
Besides, while the spec says that only CMD0 and CMD8 should have CRC in SPI mode, some SD cards (like Transcend ones) seem to require proper CRC for CMD55/ACMD41 - if you want to be on the safe side, simply use a precalculated value for them.
Also, while SPI doesn't require pullups/downs by itself, throwing a 47k pullup on MISO may be a good idea; some devices leave their DO pin high-Z under specific circumstances (not initialized e.g.), and floating pins can always be a source of strange problems. If your uC has 3.3 Vcc, you may use internal pullups; if it's 5V, don't do that unless your MISO line has a proper 5->3.3V logic translation already.
Further reading:
How To Use MMC/SDC
SD Specifications Part 1 Simplified Physical Layer Simplified Specification - most importantly sections 6.4.1 Power up and 7.2.1 Mode Selection and Initialization with Figure 7-1: SD Memory Card State Diagram (SPI mode)
The specs for SD Cards are available on sdcard.org. The simplified version left out some details, but you should look for example at the figure 7-2 in part 1, where the initialization sequences are explained for SDHC and SD cards.
MicroSD cards <= 2 GB can work like older cards, so they should give you 0x00 result for CMD1 eventually. This may need more than a few retries, as the card can use the external clock from the SPI bus to drive some internal processing.
Adding to @vaxquis excellent answer, I'd like to quote the corresponding chart from the "Physical Layer Simplified Specification Version 4.10, ©Copyright 2001-2013 SD Group (Panasonic, SanDisk, Toshiba) and SD Card Association" (Figure 7-2: SPI Mode Initialization Flow):
SD Card SPI Init Sequence
Here you can see which commands to send in which order and what the responses tell us about the type of card. I think it is desirable that a device supports as many cards as possible; and as long as it comes to the basic operations of reading and writing blocks of 512 bytes, that should be doable for at least all V1.x and V2.0 SD and HC cards.
I offer this as another possibility.. In SPI mode, Samsung MicroSD EVO 32GB require all command codes to have valid CRC codes. I bet they are not the only ones. I read a comment where the person believed all cards above 32GB might be that way. I have been debugging a bug for over a week. My code wouldn't work until all codes sent to the card had valid crc codes. I used this to calculate all the CRC codes https://github.com/hazelnusse/crc7/blob/master/crc7.cc I even tried using a command 59 to turn off the CRC codes, nope. I hope this saves someone else a lot of time and effort.
My initialization code with CRC values..
Power On..
Clock card at least 74 (I use 80) cycles with cs high
CMD0 0, crc=0x95
CMD8 0x01aa, crc=0x87
CMD58 0, crc=0xfd
CMD55 0, crc=0x65
CMD41 0x40000000, crc=0x77
CMD9 0, crc=0xaf
CMD16, 512, crc=0x81 (If you want block length of 512)
Some random other commands..
CMD17 0, crc=0x3b (Read one block)
CMD18 0, crc=0x57 (Read multiple blocks)
CMD24 0, crc=0x6f (set write address for single block)
CMD25 0, crc=0x03 (set write address for first block)
Are you sure your SPI bus is at 400 kHz? The initialization must happen with the SPI bus running at 400 kHz until the SD Card reports it is in the idle state, upon which the SPI bus clock rate may be increased (the exact maximum seems to vary from manufacturer to manufacturer, but it seems like 12 MHz is a safe bet for most cards).
Also, according to this: http://elm-chan.org/docs/mmc/mmc_e.html CMD1 is the proper initialization. CMD8 is only required to query the voltage range, which should not be an issue with non-SDHC (<= 2GB) cards.
  • \$\begingroup\$ actually, many SD cards (mostly newer ones, my Sony SR-32C4 32GB being one) won't start at all without CMD8 issued beforehand. Also, the clock is usually not an issue, as long as it's within sensible range. \$\endgroup\$
    – user20088
    Jun 4, 2016 at 22:39
-3
Maybe this is too late, but the response from the card is O.K.! After CMD0, response must be 0x01 - this means that card IS in IDLE state and ready for work. If you have something like 0b00000101 the 1 on the 2-nd place says that this is illegal command and the 1 on the 0-s place says that sard IS still in IDLE state and ready for work. If the response is 0x00 it means that card IS NOT in IDLE state and you must send another RESET command.
  • \$\begingroup\$ have you read the question at all? OP clearly said I tried this, but I am getting 01 even for CDM1 - getting IDLE in response to CMD1 in NOT OK. You're not addressing his real problem with your "answer". \$\endgroup\$
    – user20088
    Jun 4, 2016 at 14:01
