Before starting on my project, I need to familiarize myself with any possible silicon errors in my dspic.
I saw this for PIC micros, but it doesn't apply to the dsPIC33F that I'm using.
I found a post somewhere (that I can no longer find for some reason) that says I can use MPLAB X to get the silicon revision. It said to go to the Dashboard, and then click the refresh button on the left side. I did that, and then right-clicked the project and chose "Copy to Output". The problem is that the silicon revision is not in the output, shown below:
dspic33f_spi
Device
dsPIC33FJ64MC802
Checksum: 0x03AC
Compiler Toolchain
XC16 (v1.11) [C:\Program Files (x86)\Microchip\xc16\v1.11\bin]
Memory
RAM 17714 (0x4532) bytes
RAM Used: 0.0%
RAM Used: 0 (0x0) Free: 17714 (0x4532)
RAM Reserved: Production Image
Flash 22016 (0x5600) words
Flash Used: 0.0%
Flash Used: 0 (0x0) Free: 22016 (0x5600)
Flash Reserved: Production Image
Debug Resources
Program BP Used: 0 Free: 2
Data BP Used: 0 Free: 2
Data Capture BP: No Support
Unlimited BP (S/W): No Support
Debug Tool
PICkit3
Other Project Info
RAM Reserved Memory
Production Image
Flash Reserved Memory
Production Image
Control Points.
System Properties
MPLAB X IDE v1.85 - dspic33f_spi : default
os.name : Windows 7
os.arch : amd64
os.version : 6.1
sun.arch.data.model : 64
java.version : 1.7.0_17
java.vm.version : 23.7-b01
java.runtime.version : 1.7.0_17-b02
java.specification.version : 1.7
netbeans.user : C:\Users\dave\AppData\Roaming\.mplab_ide\dev\v1.85
netbeans.projects.dir : C:\Users\dave\MPLABXProjects
netbeans.home : C:\Program Files (x86)\Microchip\MPLABX\mplab_ide\platform
java.io.tmpdir : C:\Users\dave\AppData\Local\Temp\
user.home : C:\Users\dave
user.country : US
user.language : en
sun.jnu.encoding : Cp1252
file.encoding : Cp1252
file.separator : \
Can anyone provide a way to get the information I need? The date code is 1243EWT, which IIRC means that it was manufactured on the 43rd week of 2012.
