I have an existing LED light curtain but I would like to redo it in more robust way. It has a main cable with 6 branches hanging down like this:
Battery&DC-DC___________________
                o  o  o  o  o  o
                o  o  o  o  o  o
                o  o  o  o  o  o
                o  o  o  o  o  o
At the moment the T-branches are just twisted and soldered around the main but soldering tends to break because branches are flexing a lot.
Are there some recommended T-connectors available? It can be permanent or detachable.
Edit: The wire gauge is not fixed, I think at the moment it uses 0.75 mm²
  • \$\begingroup\$ What gauge wire? \$\endgroup\$ – JYelton Aug 2 '13 at 7:02
  • \$\begingroup\$ You could physically stiffen the electrical connection, so the flexing will take place at an intact part of the hanging cables. \$\endgroup\$ – Wouter van Ooijen Aug 2 '13 at 8:27
Something like a 3M Scotchlok T-Tap connector might be what you want.
Be sure to use stranded wire if your application requires flex, it will impart less stress to connections (soldered or not).
t-tap connector
| improve this answer | |
  • \$\begingroup\$ Looks very neat \$\endgroup\$ – Petteri H Aug 5 '13 at 5:36
