Looking at the frequency choices for buck regulators, is there a defined "good" range for a particular context?
Looking at datasheets, manufacturers extoll the virtues of "better transient response". But it's difficult for me to know what minimal transient reponse is actually required in any given situation.
In front of me I have an LM2596 regulator I bought off eBay for US$3. It's a nice simple design at 150 kHz. It's not particularly small mind you, but that's OK in many scenarios.
Going higher frequency results in smaller inductors and faster transient response. You pay a price for this in low ESR ceramic capacitors, more expensive magnetics and a more critical layout. Plus lower efficiency.
So, size aside, what is 150 kHz good for and what is it not good for? I assume I could drive, say, LEDs with this, even if they had to pulse... If it was something like a Raspberry Pi, would it be a bad idea to power it from this module? How do I know?!
Looking at something like the PandaBoard, they use a TPS54320 at 500 kHz. I have another board with an FPGA (400 MHz) that uses a TPS5430 at 550 kHz. So, generally speaking, can I assume 500 kHz is enough response for anyone?
  • \$\begingroup\$ If transient response is the concern, then for every design get the worst case transient and simulate the scenario using simulators ( almost every company has given simulators for their parts ), as far as i know transient response will depends on How fast LC circuit releases the stored charge. How fast the loop reacts to the transient( Mode of control -> Current or Voltage mode control, compensation network details) \$\endgroup\$
    – user19579
    Commented Aug 2, 2013 at 12:13
6
Higher frequency does allow for a smaller inductor at the same current, but does not necessarily mean better transient response. The transient response is a function of how the control loop is tuned. The switching period is a hard lower bound on transient response, but in reality the control loops are tuned to that pulses average out and therefore they respond slower than that. 20x the pulse repetition period would not be unusual.
Your statement of paying a price for higher frequency in low ESR caps also doesn't make sense. You'd be using low ESR caps anyway in most cases. Even if the control loop doesn't require the low ESR, the ripple current usually does. Caps that aren't specifically low ESR usually can't handle the ripple current at the output of a switching power supply. Note that higher frequency actually reduces this ripple current.
It is also not true that higher frequency implies lower efficiency. At some point it does because the switch can't transition between off and on instantly, but there is a lot of room above 150 kHz before that becomes a dominating factor. 150 kHz is a rather low frequency for a integrated switching chip nowadays.
If low transient excursions are important to you, put a lot of capacitance on the output. However, make sure your type of switcher is OK with that. Depending on the type of control scheme, some require a little ESR on the output. One way to deal with that is to put a little resistance in series with the output before the capacitors, like 50 mΩ. See the datasheet. That will satisfy the control requirements and then you can put as much capacitance afterwards as you want. This allows you to trade off transient excursions for a little overall regulation.
Overall, you need the read the datasheet for any switcher chip very carefully. Make sure to satisfy all conditions. There are various different control schemes, so there is no universal answer. As always, the datasheet is the real guide.
  • \$\begingroup\$ Yes, I was struggling a bit to understand all the ins and outs of buck converter design - I drew a direct correlation between frequency and transient response. If I go back and read the datasheets carefully, they talk about "input voltage feed forward" and "current mode topology" for fast transient response. Which is what you've been saying. \$\endgroup\$
    – carveone
    Commented Aug 2, 2013 at 15:11
  • \$\begingroup\$ (Just in case). So if I had a voltage mode buck at 500kHz and something like a LTC8610 which has current mode control, at the same frequency, the latter would have better transient response? Of course, I'm still not sure in which circumstances that would be important but I think I've got it now :-) \$\endgroup\$
    – carveone
    Commented Aug 2, 2013 at 15:26
  • \$\begingroup\$ @carv: There are various control schemes, with some providing good transient response more easily than others. However, individual implementations can vary significantly, and in some cases the control dynamics can be tweaked by the user, so you really need to look at the datasheets for whatever parameter you care about. Most switchers will have good enough transient response for most cases. \$\endgroup\$ Commented Aug 3, 2013 at 12:01
The transient response question is complex, with many inputs.
Power train considerations include:
  • the size of the output inductor
  • the amount of output capacitance
  • the type of output capacitance (ceramic, electrolytic)
Control considerations include:
  • the control scheme (voltage mode, current mode, V2)
  • the operating frequency
  • the operating mode (DCM, BCM, CCM)
The transient response is only indirectly related to switching frequency, in that the switching frequency imposes an upper limit on the maximum closed-loop crossover frequency that's realistically achievable. (Generally, the crossover should be at most 1/4 of the switching frequency.) A 1MHz switching frequency buck with a loop crossover at 100Hz will be just as slow in responding as a 100kHz switching frequency buck with the same 100Hz crossover.
The mode of operation is also important. Operating a buck in DCM (discontinuous conduction mode, where there's a period of zero inductor current per switching cycle) helps damp the output filter response and makes compensation easier (and allows for a higher crossover vs. other modes). If the converter transitions into CCM, the response abruptly changes (you get a large gain peak and an abrupt phase shift) and you generally need a lower crossover frequency to ensure stability (vs. DCM)
Current-mode control can provide better transient response (the inner current loop can generally respond faster than the outer voltage loop) with some penalties (current sensing, slope compensation to avoid subharmonic oscillation, etc.) V2 control can also improve transient response vs. a normal voltage loop, but is complex as well (sensing the capacitor current can be tricky).
I could go on, but I think you get the general idea.
If you're designing the buck yourself, you should model/simulate/iteratively test to get the optimal transient response for your particular converter. If you're buying one from someone, they should have this analysis available for you. You cannot generalize based on switching frequency.
  • \$\begingroup\$ What you say about the closed look frequency is interesting - I was assuming that higher freq = faster response but it could be untrue if the implementation differs. I think I was hoping for a universal answer but there isn't one :-) I do wonder about the question of "What transient response is required for X". Eg: If I bought an FPGA module, or an LED, or a sensor could I say that this item needs this level of responsiveness and thus requires this type of regulator. I guess that's an answer the manufacturer should give me though. \$\endgroup\$
    – carveone
    Commented Aug 2, 2013 at 15:18
  • \$\begingroup\$ Higher closed loop crossover frequency does mean faster response. My point was that the loop crossover frequency cannot be gleaned by comparing switching frequencies. \$\endgroup\$ Commented Aug 2, 2013 at 18:28
You may be misunderstanding slightly. There is usually little direct correlation between the transient response of a SMPS and its operating frequency. The transient response is decided by the feedback loop which i believe has a bandwidth of few thousands of kilohertz in most cases. How well the SMPS responds depends on how the feedback loop molds the open loop transfer function into a shape that exhibits the required bandwidth and stability criteria. This can wary a lot between designs with the same control chip and same operating frequency. The feedback path can be either internal to the chips or made out of external components. Check if the different SMPS give you a bandwidth specification that you can then compare if it's implemented internally in the chip. If it's external then you can decide the response by placing proper external components, within limitations of course.
  • \$\begingroup\$ Yes. I was correlating directly. I should read the datasheets and not hobby forums! I'm pretty sure that EDN or EETimes had an article that said that though... The web says a lot of things. \$\endgroup\$
    – carveone
    Commented Aug 2, 2013 at 15:22
