6
The reason I wanted to ask this question is because I was designing a project for an electronics course I was taking last semester. The idea was simple. Take input from a microphone and amplify it sufficiently to turn an LED on/off depending on the frequency that was passed. Now, in my research I came across an article that stated OP Amps (unless very expensive) are a source of tremendous electrical noise in their high-gain applications. So, I resolved to a two-stage design with a BJT amplifier (~50 gain) and an OP Amp (~gain 2) for an overall gain of 100 to reduce the alleged noise issues.
So, in short, why do OP Amps have electrical noise issues (if at all), and what is the source? Why are Op Amps more noisy than other types of amplifiers (BJT and MOSFET, for example)?
It seems that any application of amplifiers in general would potentially be a source of 'amplified' noise if there exists such noise in the input signal. Perhaps Op Amps lack sufficient filtering capabilities that are inherent to BJT and MOSFET design? Op Amps are, internally, transistors anyway, so why the noise difference?
    \$\begingroup\$ In short, physics. \$\endgroup\$ Aug 2, 2013 at 16:37
  • \$\begingroup\$ Very insightful. \$\endgroup\$
    – sherrellbc
    Aug 2, 2013 at 16:51
  • \$\begingroup\$ Honestly, the wikipedia entry gives a very concise answer. Most of what you see in the opamp internally is going to be thermal noise that is amplified and also noise relating from the fact that electrons aren't flowing in a continuous state. There are interactions at the quantum level that cause noise. \$\endgroup\$
    – scld
    Aug 2, 2013 at 17:28
    \$\begingroup\$ "What is the root cause of noise?" and "Are op-amps more noisy than other kinds of amplifiers, and why?" would each be a very big topic address in a single answer. Either one borders on "too broad" for this site. Could you at least split this into two different questions so we don't have to write a complete textbook to answer? \$\endgroup\$
    – The Photon
    Aug 2, 2013 at 17:29
    \$\begingroup\$ Can you link the article that says "OP Amps (unless very expensive) are a source of tremendous electrical noise"? \$\endgroup\$
    – The Photon
    Aug 2, 2013 at 17:42
6
I doubt this is true, especially if you consider the noise factor for the same circuit gain (but another answer might give more concrete information).
TI has a couple of good app notes on this:
Chapter 10 of Op-amps for Everyone
Noise Analysis for High-speed Op-amps
In short, the feedback resistors and the op-amp's input stage transistors both contribute to noise.
Op-amp circuits can be filtered to whatever bandwidth you like. It only requires adding an extra capacitor or two to the op-amp circuit, or for higher-order filtering adding an additional filter stage after the high-gain stage. Which would be equally required for a discrete circuit.
  • \$\begingroup\$ Note that Op-amps for Everyone has many errors in the noise calculation examples; I wouldn't recommend it. TI has some videos that I think are correct: training.ti.com/node/… \$\endgroup\$
    – endolith
    Mar 23, 2021 at 18:19
There will always be noise in a circuit. No amount of filtering will get rid of thermal noise. As to why an "op-amp" is more than a BJT or FET, it's because the internal circuitry of an op-amp is actually just more than one transistor. Each of those stages will introduce their own noise.
