7
I want something for my power that acts like a diode, but without the voltage drop, to protect the circuit from damage if the batteries are connected the wrong way. Is this even possible?
  • 5
    \$\begingroup\$ I like Microsoft's mind-blowing invention, here. \$\endgroup\$ – tyblu Dec 12 '10 at 21:56
  • \$\begingroup\$ @tyblu, Interesting how it has been invented already: US Patent 5431575. \$\endgroup\$ – Thomas O Dec 12 '10 at 22:44
  • 4
    \$\begingroup\$ @Thomas O, Must have either sold his soul to MS or conveniently disappeared. \$\endgroup\$ – tyblu Dec 12 '10 at 22:51
  • \$\begingroup\$ @tyblu Either that, or Microsoft didn't do a thorough check on possible prior art - OR - Microsoft knows it's prior art, but knows the small company or individual doesn't stand a chance against their small army of lawyers. \$\endgroup\$ – Thomas O Dec 12 '10 at 23:24
  • \$\begingroup\$ @tyblu are you sure you haven't sold your soul to MS since this is the second time you have linked it? :-) @ThomasO That patent is for the mechanical aspects of the holder and not the electronics. I am sure MS is capable of designing a different holder or licensing it. \$\endgroup\$ – Kellenjb Dec 13 '10 at 6:04
10
Put the diode across the supply connections so that it is non-conducting, with a fuse ahead of it. The diode will conduct if the supply is reversed, and blow the fuse. There won't be any voltage drop.
alt text
| improve this answer | |
  • \$\begingroup\$ how does this protect the circuit? it just tells me that i've plugged it in the wrong way. \$\endgroup\$ – Dean Dec 12 '10 at 22:27
    \$\begingroup\$ @tyblu The fuse is in series with the battery line and the diode is in reverse across the supply. It will work. I think you're thinking of putting the fuse in series with the diode and the load across the battery, which wouldn't serve any purpose. I have done this before and it works, but it's obviously annoying to have to replace fuses. \$\endgroup\$ – Thomas O Dec 13 '10 at 0:03
    \$\begingroup\$ @Leon Heller I hope you don't mind, I added a picture since it seemed some people weren't fully clear what was happening. Feel free to remove or replace if you aren't happy with it. \$\endgroup\$ – Kellenjb Dec 13 '10 at 5:57
    \$\begingroup\$ I believe this would be called a crowbar. \$\endgroup\$ – XTL Dec 13 '10 at 15:43
    \$\begingroup\$ You could use a Resettable Fuse (aka PTC or polyfuse), then no need to replace blown fuses. en.wikipedia.org/wiki/Resettable_fuse \$\endgroup\$ – davr Dec 14 '10 at 17:26
10
A MOSFET can be used to protect a circuit with a low voltage drop. See the following for more information:
Reverse Battery Protection with Hexfets doubles Battery Life
Advanced Power Switching and Polarity Protection for Effects
  • \$\begingroup\$ Careful with these circuits though: if you attempt to use a reverse supply voltage over the maximum voltage of the MOSFET gate (usually ±20V) it won't be pretty. \$\endgroup\$ – Thomas O Dec 12 '10 at 22:14
    \$\begingroup\$ If you need to survive larger voltages, you can either add a resistor divider or zener. \$\endgroup\$ – Nick T Dec 13 '10 at 19:21
You might try what's called a Schottky diode. A normal diode has a drop of around 0.6 V, but Schottky's are around 0.2 V. At very low currents, the drop can be even lower.
    \$\begingroup\$ I would suggest this as a comment on Leon's post. \$\endgroup\$ – Kortuk Dec 13 '10 at 22:16
    \$\begingroup\$ I should have been more clear-- I'm suggesting using a Schottky diode in series with the battery, not in parallel. I think that's different from what Leon is suggesting. (I think what Leon suggests is pretty good, but blowing fuses annoys some people.) \$\endgroup\$ – pingswept Dec 13 '10 at 22:32
  • \$\begingroup\$ I thought that might be what you meant. I Would suggest editing that into your answer. \$\endgroup\$ – Kortuk Dec 14 '10 at 1:26
I am planning to use the LTC4365, but that's overkill, because it has overvoltage and undervoltage protection built in (which I have a use for because it may be used in an automotive environment, but you might not.)
    \$\begingroup\$ Linear has many "ideal diode" type things IIRC. \$\endgroup\$ – XTL Dec 13 '10 at 15:42
    \$\begingroup\$ @XTL, Indeed, although some of them are overkill for this application. \$\endgroup\$ – Thomas O Dec 13 '10 at 20:40
