I have a USB webcam and a WiFi module which it can convert Serial data to WiFi and vice versa.
The question is can I simply convert the data coming from the webcam to serial with a USB to Serial IC (like FT232R ) and then hand it over to my WiFi Module?
Not even close. USB-to-Serial ics are usb peripherals (slaves), like the web cam. Without something in between, like a usb host (i.e., a computer) you could not get the two to talk.
  • \$\begingroup\$ you know I want to put my webcam on a robot. and my robot wants to move around my house and I want to see the webcam images with my computer. so I want to somehow convert my webcam to a WiFi IP camera. do you have any suggestion? \$\endgroup\$ – Mehrdad Kamelzadeh Aug 4 '13 at 17:26
  • \$\begingroup\$ Attach webcam to Raspberry Pi. Install "motion" on Pi. Plug USB Wifi dongle into Pi. \$\endgroup\$ – John U Aug 5 '13 at 8:15
No, you can't do it that way. You will need a USB host that interfaces to the webcam and sends the data over Wi-Fi.
This would be quite simple to do with a Raspberry Pi if your webcam is supported by Linux (those days, most are, I believe).
Simply put, no. The bandwidth required for a webcam will be much larger than you could sensibly put over serial. OK I know you can get >2MBaud of out an FT232R (with a suiteable RS232 Line driver), but that will still absolutely prevent video and make still images slow.
Fundamentally the USB Camera is a device and must connect to a USB host. The WiFi module (from the information you give) is not a USB host.
If you obtain a Raspberry Pi, you could probably use that as it is a USB host to which you can connect your camera and an ethernet (or your WiFi) module. (I only say probably as you didn't give the make/model of camera, so I don't know if suitable software is available for the Pi)
  • \$\begingroup\$ you know I want to put my webcam on a robot. and my robot wants to move around my house and I want to see the webcam images with my computer. so I want to somehow convert my webcam to a WiFi IP camera. do you have any suggestion? \$\endgroup\$ – Mehrdad Kamelzadeh Aug 4 '13 at 17:27
  • \$\begingroup\$ I'll suggest the Pi again, that could control your robot too. I've updated my reply with a link to the Pi if you are not familier with it. \$\endgroup\$ – Jason Morgan Aug 4 '13 at 19:27
  • \$\begingroup\$ @Jasom I hadn't heard about it. How can I get started with it? Shall I install linux on this device? \$\endgroup\$ – Mehrdad Kamelzadeh Aug 4 '13 at 20:12
  • \$\begingroup\$ There's lots of enthusiast sites about development of both hardware and software with the Pi, it usually comes with Linux already installed. I suggest you start with Google. P.S. If you find my answer useful, please upvote it! \$\endgroup\$ – Jason Morgan Aug 4 '13 at 21:52
