I've noticed this connector on a lot of boards, and I was wondering if anyone knew where to source them? I can't seem to find them on digikey.com anywhere. What I'd really like is to get a male connector for this to breadboard the contacts. enter image description here enter image description here
    \$\begingroup\$ That's actually a SMD board connector; it just happens to be connected to the end of a flexible cable. \$\endgroup\$ Commented Aug 7, 2013 at 0:16
  • \$\begingroup\$ Well that would certainly explain why I couldn't find them on Digikey - I was looking under the wrong categories. Any idea how one would go about breadboarding such a thing? \$\endgroup\$ Commented Aug 7, 2013 at 0:29
  • \$\begingroup\$ You'd have to solder it to a DIP adapter. \$\endgroup\$ Commented Aug 7, 2013 at 0:32
  • \$\begingroup\$ Making a custom breakout for these is a great intro to toner transfer PCB etching. If you are tricky and surface mount your pins (consider using single row right angle ones) you can avoid drilling any holes at all. \$\endgroup\$ Commented Aug 7, 2013 at 3:01
To compliment Gonziks answer, another brand that is very similar is the Panasonic F4S series:
Example
Example Picture
These look like Molex SlimStack 0.4mm or 0.5mm board to board interconnects (http://www.molex.com/molex/products/group?channel=products&key=slimstack). Breakout boards for these are not common. You'll have to either do a board spin or flywire 40 gauge magnet wire to interface with these.
