As I understand it, should maximum power transfer be when $$ R_L=R_{th} $$ then $$ P_L= P_{L(max)} $$
So that this should do the trick:
$$ P_{L}=\frac{V_{th} ^2}{R_{th}} $$
But it seems that I am doing something wrong.
It's a simple error in your reasoning. When the load resistance is equal to the Thevenin resistance, the voltage across the load is precisely 1/2 the Thevenin voltage.
Thus,
\$P_{L,max} = \dfrac{V^2_{th}}{4R_{th}} \$
Your calculation would be correct if the entire Thevenin voltage appeared across the load but that isn't the case.
  • \$\begingroup\$ I see, that explains a lot. \$\endgroup\$ – Faux_Clef Aug 10 '13 at 13:03
