I am an electronics hobbyist and I found something that I hadn't heard of before, named Memristor. I found some information about how memristors work on this site and I want to know that how it can be used. In which type of application are these components used?
  • 5
    \$\begingroup\$ @RedGrittyBrick but what are the application.How one can use this device? \$\endgroup\$
    – SSS
    Commented Aug 12, 2013 at 12:19
  • 4
    \$\begingroup\$ What are the characteristics and what are the applications are two separate questions \$\endgroup\$
    – Iancovici
    Commented Aug 12, 2013 at 17:02
  • 4
    \$\begingroup\$ @Kortuk, Would've agreed about this being too broad, but if this question is acceptable then I don't see why shouldn't this one be. \$\endgroup\$
    – Iancovici
    Commented Aug 13, 2013 at 10:29
  • \$\begingroup\$ @echad Just because someone speeds without being ticketed does not mean that you can speed without risk of enforcement of the speed limit. If that makes sense, the other was open and no one had flagged it or taken specific note. Another question being open can be a good example for meta discussions but is generally never good evidence that one question should be reopened in a comment. \$\endgroup\$
    – Kortuk
    Commented Aug 14, 2013 at 18:14
Memristors have a memory like characteristics, non-voltaile memory. So even when they're powered off they can hold on to the value. This sort of technology can replace how we design memory for computers such as RAM, SSD and Flash.
Resistive Random Access Memory (RRAM): RRAM
source
Many applications can take advantage of it such as neural networks, robotics to mimic biological entities in a new way. DARPA is attempting to build a brain using Memristor chips, designed by HP Labs, for neuromorphic computing. Memristor Synapses
source
They can also replace transistor-based crossbar latches since they take up less space. Logic design is a big area these components can contribute. From crossbar latches to memory, gates and more
There already exist memristor-based control system patents out there (here's one example)
  • \$\begingroup\$ As you have mention in your very first line how they differ from the RAM or other non volatile memory?? \$\endgroup\$
    – SSS
    Commented Aug 13, 2013 at 12:04
  • \$\begingroup\$ @user27390 they "use resistance instead of voltage or charge as the physical state variable" and take up less space \$\endgroup\$
    – Iancovici
    Commented Aug 13, 2013 at 12:08
  • \$\begingroup\$ If each memresistor has a diode in series, wouldn't that mean it would get set into the state associated with current flow in the diode direction and then permanently stuck there? \$\endgroup\$
    – supercat
    Commented Aug 13, 2013 at 16:00
  • \$\begingroup\$ @supercat That doesn't affect the memory writing scheme, it just introduces different energy requirement for setting and resetting of memristor states. Source: Design exploration of hybrid cmos and memristor circuit by new modified nodal analysis by W Fei, H Yu, W Zhang, KS Yeo. \$\endgroup\$
    – Iancovici
    Commented Aug 14, 2013 at 0:46
