I'm building a machine to help me manufacture some optical components more quickly. The machine will be powered by a plain old, "boring" 1/4 HP motor, like the ones used for various household appliances. I actually bought this one:
http://www.amazon.com/gp/product/B006P1RUOM/
The product description says: "split phase motor, 5.4 amps, 60 hertz, auto protector". The page title in case the link is dead: "A.O. Smith GF2024 1/4 hp, 1725 RPM, 115 volts, 48/56 Frame, ODP, Sleeve Bearing Belt Drive Blower Motor".
How would you choose the circuit breaker for this thing? I assume it will have to support a current larger than the stated 5.4 amps, because there's an initial shock when you power it on.
For extra safety I would prefer a 2 pole breaker. The optical items are coated with some water-based fluid during processing and, while there's no chance for the fluid to reach the inside of the box, where the motor is, I am very much in favor of taking additional safety measures whenever it's reasonably possible.
Due to the environment, it sounds like you need one of these (Residual current detector): -
This detects a difference in current between the two AC wires and trips the contacts breaking the circuit. It also has fuses for overloads and you may consider that this is enough protection.
| improve this answer | |
Assuming because you are using 115V this is going to be used in North America.
2 pole circuit breaker for 115V is pointless, it does nothing for you.
You cannot connect this in the field with wire less than 14ga, so a 15A circuit breaker is fine. The motor has it's own protection built-in.
If the environment is wet, you will be required to use a GFCI (North American version of the RCD mentioned above). You may experience nuisance tripping however. Better to design the system to no allow exposure to moisture.
