I'm trying to think of different ways to build a device that will allow me to mount it to any moving object so that the moving object will be able to discern it's speed (It DOES NOT have to be very accurate)
Requirements:
  • I just need to know a few levels of speed: not moving, slow, medium, fast, etc.
  • I want to be able to mount it on a bike, maybe a scooter, maybe a skateboard, etc.
  • Cheap - I want to be able to make this thing for
Bike computers work with a magnet mounted on a wheel and a hall effect sensor to pick up each rotation.
A velocity can be calculated by discerning the distance traveled given time. (the bike computer method is great, but it doesn't allow me to use it on a skateboard, for example)
Are there optical sensors that can be pointed at the ground?
An infrared distance sensor won't work (right?) because it is always the same distance from the ground.
What about a sound sensor? Can it measure some sort of doppler shift?
GPS is too expensive
I potentially can use an accelerometer. How would I know the difference between a stand still vs. no acceleration.
  • \$\begingroup\$ Optical mouse sensors might be worth a look at (don't know how fast they can operate). The accelerometer option will have various problems as you've highlighted. \$\endgroup\$
    – PeterJ
    Aug 16, 2013 at 5:14
    \$\begingroup\$ You could paint a black line (or whatever special color you want) on a wheel and use an LED/photodiode setup where the light bounces off the wheel into the sensor. You might even be able to get away without using the LED under certain conditions. \$\endgroup\$ Aug 16, 2013 at 5:48
    \$\begingroup\$ Just look at your smart phone with GPS and a simple speedometer app? That's pretty much for free if you have the phone already. \$\endgroup\$
    – jippie
    Aug 16, 2013 at 6:15
  • \$\begingroup\$ This could sound funny but it could work :) Make a small hump on the wheel. As you speed up, the hump will make high frequency vibrations on the vehicle. Get a vibration sensor and you could probably get some information about the speed. And if you are planning to do this for practical purposes, you really don't need to make a hump on the wheel. As the speed increases, the vibration increases in general. There are other solutions like airflow sensors as well, but I'm not sure if they are economical \$\endgroup\$
    – C--
    Aug 16, 2013 at 6:53
Yes, there are optical sensors that can measure speed. I worked at the proving grounds for a major car maker. In the past, anyone testing cars on the oval used "fifth wheels" but these were falling out of favor as of ten to fifteen years ago. Now optical sensors that measure the how the correlation of random surface texture with itself changes over time.
A similar technique is being researched to measure blood speed in blood vessels with tiny probes inserted by catheter. Same math, very different application.
There is a possibility of taking the sensor out of a wireless optical mouse, but it's unlikely to work if the distance between sensor and moving surface is more than a few cm. "Few" might mean only one! But then, you could use a lens and change that.
But anyway, what sensor can you run out and buy today? If I had more time I'd look for specific examples, but try googling for "optical flow speed sensor" and see what comes up.
  • \$\begingroup\$ How cheap are these? They sound expensive... \$\endgroup\$
    – milesmeow
    Aug 16, 2013 at 7:32
