I've always wondered this: every single modern PCB is routed at 45 degree angle increments. Why does the industry prefer this so much? Doesn't any-angle routing offer more flexibility?
One plausible theory would be that the existing tools only support 45 degree increments and that there isn't much pressure to move away from this.
But having just researched this topic on google, I stumbled across TopoR - Topological Router - which does away with the 45 degree increments, and according to their marketing materials it does a considerably better job than the 45-degree-limited competitors.
What gives? What would it take for you personally to start routing arbitrary angles? Is it all about support in your favourite software, or are there more fundamental reasons?
Example of non-45-degree routing: alt text
P.S. I also wondered the same about component placement, but it turns out that many pick & place machines are designed such that they can't place at arbitrary angles - which seems fair enough.
share|improve this question
Modern tools support arbitrary angles, so that's no longer the reason. – Brian Carlton Dec 16 '10 at 0:46
8
As a side note, when using 45 degree routing, octagonal vias will give you the greatest clearance while maintaining more copper area on the annular ring. – Kevin Vermeer Dec 16 '10 at 17:05
I'd also point out that the free gEDA PCB program has a toporouter - Not just this one. Does the same thing, and I don't think that it's due to its removal of the 45 degree limitation. – Kevin Vermeer Dec 16 '10 at 17:06
"Liquid PCB" sourceforge.net/projects/liquidpcb makes some interesting-looking traces with lots of graceful curves. – davidcary Feb 5 '11 at 15:31
@gbmhunter fixed, thanks! – Roman Starkov May 20 '16 at 12:56
up vote 31 down vote accepted
Fundamentally, it basically boils down to the fact that the software is way easier to design with only 45° angles.
Modern autorouters are getting better, but most of the PCB tools available have roots that go back to the DOS days, and therefore there is an enormous amount of legacy pressure to not completely redesign the PCB layout interface.
Furthermore, many modern EDA packages let you "push" groups of traces, with the autorouter stepping in to allow one trace to force other traces to move, even during manual routing. This is also much harder to implement when you aren't confined to rigid 45­° angles.
share|improve this answer
Accepted. For the record, TopoR claims to be able to push groups of traces better than standard tools do - although I haven't tried myself. I take your point that it's harder to program arbitrary angle autorouters, but people have done much harder things... there just isn't enough demand for this somehow (and I still don't know why :D). – Roman Starkov Dec 19 '10 at 0:20
Also, I've tried the TopoR demo, and it feels very "alpha" to me. The interface is very clumsy. – Connor Wolf Dec 19 '10 at 4:54
As for why there isn't much demand? The EDA software market is tiny is why. – Connor Wolf Dec 21 '10 at 7:17
See https://sourceforge.net/projects/liquidpcb/
It's an EDA CAD package I was writing, but developement slowed a lot when I had kids. It does not support straight tracks at all. All tracks are freely curving and take the most optimal routes to their destinations.
LiquidPCB
NOTE: liquidpcb.org is a dead link which refers to a domain seeling service. – Sempie Apr 6 '16 at 5:36
@Daniel Grillo: Thanks for the fix. I let the domain name lapse, becuase I wasn't using it any more. – Rocketmagnet Apr 9 '16 at 18:42
It looks more tidy, and enables the most tracks to be put into a given area. it's also better for controlled impedance tracks.
7
To add to this: as you do your routing on a fixed grid, parallel lines will be at least 1 gridmark away. If they make a corner together a 45° angle gives the most space between those two tracks on the diagonal. Different angles may require that these tracks start farther apart to ensure minimum spacing, resulting in less dense routing than optimal. [Note that I'm not saying that more dense is better, but often desirable.] – tyblu Dec 16 '10 at 0:15
I said "a 45° angle gives the most..." and should have said "a 45° angle gives more... than if the angle were less." – tyblu Dec 16 '10 at 1:14
@tyblu I'm sorry but this makes no sense whatsoever. Firstly, diagonal lines on gridmarks are NOT spaced 1 gridmark away but only 0.7 gridmarks away, and secondly, if you have more angles you ALWAYS have more opportunity for denser routing. How can you possibly have less chance to route densely by routing in a way that entirely contains 45 degree routing as a special case? – Roman Starkov Dec 16 '10 at 10:55
@romkyns, There are some misunderstandings. Following common design principles, you are limited to <45° corners, follow a fixed grid and an xy orientation. Achieving transitions from horiz. to vert. using <45° on a fixed grid uses more space than 45°. – tyblu Dec 16 '10 at 13:58
@tyblu Right, indeed, there was a misunderstanding on my part. Under those constraints a 45 degree joint makes sense, but those seem like very artificial constraints to me. I guess my question could then be rephrased to "why do PCB professionals still operate under these artificial constraints of x/y orientation and a fixed grid?" (I think I got my answer though: too much legacy software in this industry) – Roman Starkov Dec 16 '10 at 19:30
This predates any issues with PCB software and routing: The three main reasons we were given in electronic engineering classes in the late 1970s were:
1) The sharp outside corner of the bend can cause issues at higher frequencies as the points can act as mini antennas and radiate the signals
2) Because the outside corner of a 90 degree bend is a thin point it can be etched away easily if etching times are not very carefully controlled and so affect the thickness of the trace
3) The 90 degree inside and outside corners make that area more susceptible to problems where the etching process eats underneath the trace.
I understand how 45 degrees is better than 90 degrees, but I meant to ask why it's still used in preference to arbitrary angles and curves. – Roman Starkov Dec 19 '10 at 0:18
Another thing to consider is that it makes Gerber files smaller. Gerber files define a series of lines (among other shapes).
e.g. To draw a true circle in a Gerber file takes hundreds (thousands?) of lines. But to draw an octagon takes only eight lines.
Why are smaller gerber files better than larger ones? – tyblu Dec 20 '10 at 18:18
Another argument highlighting that the problem is ancient legacy software. @Fake, do you mean that Gerbers can now represent arcs efficiently, or that nobody cares if the design is a few tens of MB? – Roman Starkov Dec 21 '10 at 10:12
7
@tyblu, Many of the routing machines more than a year or two old still use 9600 baud serial lines. I wrote a utility that converted Gerber files into a format used in a Fuji pick-n-place that is still in use at my old company and several others. The machine's only link to the outside world was 9600 baud serial, on which sat an Irix-based PC with some proprietary software on it. I guess a 10MB Gerber is fine for you, until you're the one who has to sit and wait a half hour for it to load between designs. – Eric Cox Jan 7 '11 at 23:28
10MB/9.6kbps is about 2.5 hours; I see your point! ;) – tyblu Jan 8 '11 at 0:10
Of course this doesn't just affect the Gerbers. It also affects the design database. It takes less bits to represent a straight line between two points than an arbitrary curve. And a smaller design database is going to give a more responsive tool. You might not see the difference on a 2-layer board, but the guy designing a 16-layer PC motherboard will probably notice the difference. – The Photon Mar 6 '13 at 17:01
I don't think there exists such a strong preference for 45 degree angle. I have seen an old Tektronix Oscilloscope (Tek 2213 to be precise) board with traces that looks like hand drawn :-)
22
The reason the traces look hand-drawn is because they are. The 45° preference thing is only common on computer designed circuitboards. Your tek scope predates computer PCB design, and as such the layout was indeed done manually (with tape, to be specific). – Connor Wolf Jul 30 '13 at 17:56
@ConnorWolf: And we still complain about our PCB tools ;) Designing something like that without CAD is pretty impressive. – Rev1.0 Aug 3 '16 at 13:35
For my own PCBs I like rounded & curved tracks, no problems there as long as you are routing manually.
In most of industrial PCBs it's just a tradition due to limitations on early/current routing software.
Less sharp angles = /*marginally */ better signal quality.
The last time I bothered to look at my motherboard up close I think I noticed that all the traces were radiused at all corners – Nick T Dec 16 '10 at 2:16
9
i wouldn't say "marginally better signal quality". Radiused corners to the point of laser trimmed "rounding" may be mandatory for operation at high frequency. – Mark Dec 16 '10 at 2:40
The primary reason is that it makes for an easier problem set, and can be easier to design. There are some useful properties that a 45/90 degree system provides. The primary reason I'll say is that it lets you keep your desired grid spacing without a big penalty.
If you start from a point in a grid, each cardinal direction (up, right, down, left) will arrive at an adjacent grid point at 1 unit. Any 45 degree angle will also arrive at an adjacent point, although the distance will be (sqrt 2) units. If you were to use an angle such as 30 or 60 degrees, you would arrive at a midpoint between a grid point, which would require you to have a finer grid. A finer grid increases the computation time for path evaluation and may make it more difficult to cleanly optimize the circuit.
The TopoR software uses a completely different algorithm from the typical router, which makes it unique. The PCB designs that TopoR makes looks similar to old hand-drawn PCB layouts from the 60's-70's.
But "grid spacing" is just begging the question, as the concept of a "grid" is just an artifact of XY design. – markrages Dec 17 '10 at 19:06
Hadn't thought of it that way. You're right – W5VO Dec 17 '10 at 19:44
Aligning things on a grid helps to avoid situations where when using e.g. 5 mil tracks with 5 mil spacing, there ends up being a 14 mil space on one side of a component where it would be useful to have a track, while on the other side there's a 7-mil space that could just as well be a 5-mil space. If one has tools that can efficiently move things around while keeping a layout tidy, one could simply shove the component and some tracks to expand the 14-mil gap to 15 mils, but if one can't move things so nicely, it's easier to start with a grid and avoid such problems in the first place. – supercat Apr 25 '11 at 16:20
I read that historically PCB production machines had only 90/45/0 movements, but most importantly, 45 degree is preferable to 90 degree curves because in the dol times 90 degree turns were prone to deterioration, so it was more likely that a 90 degree turn would lose copper and break the connection... so before software, hardware reason... it's all about history, and legacy
discard
