I have a Samsung PS43E450 TV (pic here). I lost the power cord. Can I just use the power cable from my PC (since it fits in the slot), or will it blow up?
  • \$\begingroup\$ Here's my suggestion on how to make this question not off-topic here. Ask it in the context of "Is there any difference in power cords that fit [this] type of socket?" or "Are all power cords that fit [this] socket configuration the same?" Then the question becomes relevant for electronics design, and helps you out with your TV. The answer should illustrate that the IEC connector is a standard, but that the other end may vary by region. \$\endgroup\$ – JYelton Aug 17 '13 at 6:01
    \$\begingroup\$ The general rule is that simple power leads are fine to swap. Power bricks are not ok to swap without carefully checking the specs. \$\endgroup\$ – Peter Green Apr 4 '16 at 18:13
Yes, no problem. That's the same connector.
There could be issues if you bought the TV in a country with different mains voltage. You'd have to check with the manual/label on the back if it works with the voltage of your current country then.
That's a common IEC-60320 C13 socket. Any cable with a c14 plug at one end, and your local outlet type at the other will work. These are standard off the shelf cables.
