Is is OK to drive the gate voltage of an n-channel MOSFET higher than the drain voltage?
The scenario is turning on a circuit with a sensor that outputs higher voltage than the circuit runs on. Specifically, a 5V sensor and a 3.0V circuit.
The MOSFET I have available is a 2n7000.
Not only is it OK, it's a normal mode of operation for every MOSFET in a switching application.
MOSFETs are typically selected precisely because the drain voltage can be made very low when switched on, usually lower than a BJT. If the drain voltage were higher, and any significant current were being switched, then the MOSFET would get very hot, since power is the product of current and voltage: \$P=IV\$.
