I don't understand my errors in QSys, can you help me? I'm trying to go through this exercise: http://www.cs.columbia.edu/~sedwards/classes/2013/4840/lab3.pdf
In Qsys when I connect the components I get the following error complaining about the connections which the instructions don't say how to wire:
Error: System.nios2_qsys_0: Reset slave sram_0.avalon_slave_0 not connected to instruction_master.
Error: System.nios2_qsys_0: Exception slave sram_0.avalon_slave_0 not connected to instruction_master.
Error: System.sram.avalon_slave_0: Interface must have an associated clock
Error: System.sram.avalon_slave_0: Interface must have an associated reset
Error: System.leds.avalon_slave_0: Interface must have an associated reset
Error: System.nios2_qsys_0.data_master: leds.avalon_slave_0 (0x0..0x3f) overlaps jtag_uart_0.avalon_jtag_slave (0x0..0x7)
Error: System.nios2_qsys_0.instruction_master: leds.avalon_slave_0 (0x0..0x3f) overlaps jtag_uart_0.avalon_jtag_slave (0x0..0x7)
Error: System.sram.avalon_slave_0: sram.avalon_slave_0 must declare an associated reset
Error: System.leds.avalon_slave_0: leds.avalon_slave_0 must declare an associated reset
Warning: System.leds.reset: Interface has no signals
Warning: System.sram: sram.conduit_end must be exported, or connected to a matching conduit.
Warning: System.leds: leds.conduit_end must be exported, or connected to a matching conduit.
Warning: System.jtag_uart_0: Interrupt sender jtag_uart_0.irq is not connected to an interrupt receiver
I can reduce the number of errors but I can't get'em down to 0 and I don't really know what I'm doing since there is no instruction how to connect the connections. Can you help me?
There is probably nothing wrong with the VHDL.
library ieee;
use ieee.std_logic_1164.all;
entity de2_sram_controller is
port (
signal chipselect : in std_logic;
signal write, read : in std_logic;
signal address : in std_logic_vector(17 downto 0);
signal readdata : out std_logic_vector(15 downto 0);
signal writedata : in std_logic_vector(15 downto 0);
signal byteenable : in std_logic_vector(1 downto 0);
signal SRAM_DQ : inout std_logic_vector(15 downto 0);
signal SRAM_ADDR : out std_logic_vector(17 downto 0);
signal SRAM_UB_N, SRAM_LB_N : out std_logic;
signal SRAM_WE_N, SRAM_CE_N : out std_logic;
signal SRAM_OE_N : out std_logic
end de2_sram_controller;
architecture dp of de2_sram_controller is
begin
    SRAM_DQ <= writedata when write = '1'
                    else (others => 'Z');
    readdata <= SRAM_DQ;
    SRAM_ADDR <= address;
    SRAM_UB_N <= not byteenable(1);
    SRAM_LB_N <= not byteenable(0);
    SRAM_WE_N <= not write;
    SRAM_CE_N <= not chipselect;
    SRAM_OE_N <= not read;
end dp;
library ieee;
use ieee.numeric_std.all;
entity de2_led_flasher is
port (
clk : in std_logic;
reset_n : in std_logic;
write : in std_logic;
address : in std_logic_vector(4 downto 0);
leds : out std_logic_vector(15 downto 0)
end de2_led_flasher;
architecture rtl of de2_led_flasher is
type ram_type is array(15 downto 0) of
signal RAM : ram_type;
signal ram_address, display_address : unsigned(3 downto 0);
signal counter_delay : unsigned(15 downto 0);
signal counter : unsigned(31 downto 0);
begin
ram_address <= unsigned(address(3 downto 0));
process (clk)
begin
if rising_edge(clk) then
if reset_n = '0' then
readdata <= (others => '0');
display_address <= (others => '0');
counter <= (others => '0');
counter_delay <= (others => '1');
else
if chipselect = '1' then
if address(4) = '0' then
if read = '1' then
readdata <= RAM(to_integer(ram_address));
elsif write = '1' then
RAM(to_integer(ram_address)) <= writedata;
end if;
else
if write = '1' then
counter_delay <= unsigned(writedata);
counter <= unsigned(writedata) & x"0000";
end if;
end if;
else
leds <= RAM(to_integer(display_address));
if counter = x"00000000" then
counter <= counter_delay & x"0000";
display_address <= display_address + 1;
else
counter <= counter - 1;
end if;
end if;
end if;
end if;
end process;
end rtl;
I uploaded my files here.
Update
I tried to make all the changes from the answer here and I still get some error messages:
Error: System.nios2_qsys_0: Debug slave nios2_qsys_0.jtag_debug_module not connected to instruction_master.
Error: System.nios2.data_master: leds.avalon_slave_0 (0x0..0x3f) overlaps jtag_uart_0.avalon_jtag_slave (0x0..0x7)
Error: System.nios2.instruction_master: leds.avalon_slave_0 (0x0..0x3f) overlaps jtag_uart_0.avalon_jtag_slave (0x0..0x7)
Error: System.clk_0.clk_reset/leds.reset: Missing connection end (try "Remove Dangling Connections")
Warning: System.nios2: nios2.jtag_debug_module must be connected to an Avalon-MM master
Update 2
Now I try to assign the clock/reset pins to the sram but there are no options for that:
    \$\begingroup\$ I took a quick look at the assignment, and as far as I can see you are instructed to use SOCP builder - the predecessor to QSys. There are several differences between these two tools, so that might be the origin of you problems. Besides that, it is almost impossible to help without being able to reproduce the problem. I suggest that you share your project files so others can see for them self instead of just looking at a screenshot. \$\endgroup\$
    – trondd
    Aug 18, 2013 at 5:23
  • \$\begingroup\$ @trondd Thank you for the comment. I uploaded the files here: bayfiles.net/file/UPWx/n3zhyB/lab3.zip I think you need Quartus II to help me but it's the free version that I use so you can download it if you don't have it and if SOCP builder can do it then QSys should be able to do it. I'm using the version 13 of Quartus II. \$\endgroup\$ Aug 18, 2013 at 7:34
    \$\begingroup\$ Bayfiles is too painful to use. If you sling the project on Github I will help you get it working. \$\endgroup\$
    – shuckc
    Aug 19, 2013 at 15:28
At least the following need fixing:
  • Break the link between clk_0\clk_in_reset and jtag_uart_0\reset - you have made a bad connection (at random?) here in an attempt to fix warnings.
  • In System Contents on the nios2 block
    • Leave custom_instruction_master should be disconnected
    • Jtag MM slave jtag_debug_module should be disconnected for now - you will sill have external debugging via. the FPGA JTAG lines without connecting this.
  • Signal clk_in_reset in the clk0 Clock Source needs to be exported. Nothing is driving your entire system reset line at the moment, so nothing will work. Later you can tie the exported signal appropriately to a board level reset. To do this: double click in the export column and type "reset_in" or similar.
  • The LED driver component leds has a port called conduit_end. This will be the wires you will connect to pins on the chip to drive the LEDs. To get this signal out of QSYS you also need to 'export' it as before - double click in the export column, type a name like "led_pins" and then this warning will be gone: Warning: System.leds: leds.conduit_end must be exported, or connected to a matching conduit.
  • You added an Avalon MM-slave port on the leds component without fully-specifying the interface details. At least you need to say which other ports of leds control the clock and reset for those memory accesses. This is how you fix this warning: Error: System.leds.avalon_slave_0: leds.avalon_slave_0 must declare an associated reset
    • Open up the component editor for leds by right clicking it in the library (NOT the design), then choose Edit....
    • Go to the Interfaces tab
    • Find the section called avalon_slave0 (Avalon Memory Mapped Slave) and choose values for the Associated Clock and Associated Reset dropdown boxes.
    • Click Finish from the Component Editor.
    • Return to QSYS and hit File -> Refresh System
  • You also need to edit the leds component and on the Interfaces tab, click Remove Interfaces with No Signals button in order to delete the empty interfaces (reported as System.leds.reset: Interface has no signals). These are often auto-created by QSYS when it badly auto-detects your interface setup (inferred from port names). You need to remember to clean them up. Save the component and then reload QSYS to see this one go away.
General point of order: try not to exit the component manager while it has warnings. You should fix those before moving on to integration.
  • Your sram should definitely have a clock and reset signal added on the internal side to go with the Avalon-MM interface, and the interface needs configuring to use them as with leds.
  • If the sram block is supposed to drive an external memory chip through the conduit port, rather than use internal block rams, you will have a great deal of fun getting that to work.
    • Consider replacing sram module with stock parts for now - look under Library -> Memories and Memory Controllers -> On-Chip -> On-Chip Memory (RAM or ROM). That will use block rams to implement your Nios RAM without having to use external memory - sufficient to see the CPU boot over JTAG.
  • connect jtag_uat_0\reset to clk0\clk_reset, so that the JTAG uart peripheral is reset with the rest of your system.
It is not difficult to build this stuff in QSYS once you get the hang of it - if you haven't already then work through the Altera video tutorials at altera.com to get to grips with the tool.
The reason why you need to link up the clock/reset for every Avalon-MM port (and declare as such to QSYS) is so that it can check the clock domains and insert clock crossing logic for you when required. QSYS can cross domains, burst settings, memory widths and base addresses - it's great for this stuff.
  • \$\begingroup\$ Thank you for the extensive answer. I made all the changes you mention and I got 9 errors left. Your answer above has been very informative, perhaps you can take a look at my results trying to solve all the problems? I don't understand 1) "Leave custom_instruction_master should be disconnected" - does it just mean "leave custom_instruction_master disconnected"? I also didn't understand "If the sram block is supposed to drive an external memory chip through the conduit port, rather than use internal block rams, you will have a great deal of fun getting that to work." but will try to learn. \$\endgroup\$ Aug 20, 2013 at 9:53
    \$\begingroup\$ If I fix up the design and stick it on the internet I think I'll be doing the future students of 'CSEE W4840 Embedded System Design Lab 3' a disservice. And I'm not sure if derivatives of that design can be shared - there's no license I can see. \$\endgroup\$
    – shuckc
    Aug 23, 2013 at 10:08
    \$\begingroup\$ 1) You still don't have clock/reset pins assigned on the sram module's Avalon-MM interface \$\endgroup\$
    – shuckc
    Aug 23, 2013 at 10:09
  • \$\begingroup\$ Thank you. But I don't understand how to assign clock/reset pins on the sram? Can you please give me a little more detail? (I'm not following the course, I'm learning this becacuse I'm interested.) \$\endgroup\$ Aug 24, 2013 at 14:29
