I am looking for a way to connect my logic analyzer (an inexpensive Saleae which is intended for 1.8-5V targets) and a couple of other pieces of analysis equipment to a digital source with signals in the 12 V range. I see that there have been a couple questions on this Stack Exchange about connecting 12 V to 5V in a one-way capacity, but I'd like a solution like this transceiver chip that is used in the Logic Sniffer input buffer wing. Does a transceiver chip like this exist? If not, is there some way that I could go about building a circuit like this that would translate between high and low voltages?
    \$\begingroup\$ Google "level shifter", plenty of circuits / devices around. \$\endgroup\$
    – John U
    Commented Aug 21, 2013 at 6:49
  • \$\begingroup\$ Thanks! I googled a bunch of terms before posting here, trying to find what I was looking for, but I didn't know that "level shifter" was the term to search on. I think that your comment answers my question. \$\endgroup\$ Commented Aug 21, 2013 at 13:07
  • \$\begingroup\$ hagtech.com/pdf/translator.pdf \$\endgroup\$
    – AKR
    Commented Aug 21, 2013 at 17:36
The easiest way is to simply put in a resistive divider. Two resistors is all you need (or one resistor and a Zener diode.) Adding an input step that's 1 kOhm up to signal and a 3.3V Zener from signal to ground would retain useful input capability down to a few volts, while being very resilient to overvoltage. At 12V, you'd see about 9 mA through the Zener, which can typically take up to 100 mA before dieing.
There are two draw-backs:
1) There is some capacitance in the Zener, plus adding the resistor to the input, will lead to some worsening of signal performance. The time constant of a 100 pF Zener with a 1 kOhm resistor is RC == 1000*100e-12 == 1e-7 seconds; meaning that signals faster than approximately a megahertz will run into rise time problems. (Thumb and forefinger here -- signals below will see some problems; signals above will see more. The -3dB point of this filter is at 1.5 MHz)
2) There will be some current drain on the signal bus. 9 mA is actually not insignificant to some weaker output stages -- various microcontrollers may be as weak as 2 mA drive capability. You have to check how much current the 12V signal can source.
Other options include various level translators. You can build a simple level translator with a single N-channel MOSFET. This doesn't have the current problems above, although it will still require the 12V signal to be able to sink a 3.3V signal at several milliamperes (This is generally not a problem.)
This has the benefit (or draw-back) that if the input pin goes low (as an output) then it will try to drive the 12V signal low, too. Note that CircuitLab uses a weird symbol for N-channel MOSFET -- typically, there are two lines for the source, and the arrow points in in the center.
  • \$\begingroup\$ Also, if it doesn't need to be bi-directional, you can probably replace the MOSFET with a diode, cathode pointing at the 12V signal. \$\endgroup\$
    – Jon Watte
    Commented Aug 21, 2013 at 3:38
  • \$\begingroup\$ The Sparkfun Logic Level Converter has almost exactly the same FET circuit you drew. Its schematic shows the internal (parasitic) diode of the FET pointed so that when the 12V signal goes Hi, the diode turns off, but when the 12V signal goes to GND, the diode pulls the low-voltage signal to GND also. \$\endgroup\$
    – davidcary
    Commented Aug 22, 2013 at 15:33
  • \$\begingroup\$ It's not a "parasitic" diode, it's a "body" diode. In on sense, MOSFETs are diodes, just like BJTs are diodes. There's nothing "parasitic" about it. The main problem IMO is that CircuitLab uses a less common symbol for MOSFETs than most other schematic programs. \$\endgroup\$
    – Jon Watte
    Commented Aug 23, 2013 at 0:22
  • \$\begingroup\$ Fairchild AN9010, page 8, mentions a parasitic diode. I thought they were talking about the FET "body" diode? \$\endgroup\$
    – davidcary
    Commented Aug 24, 2013 at 5:26
  • \$\begingroup\$ Quite possibly -- that's the first time I've heard it referred to as "parasitic" though! \$\endgroup\$
    – Jon Watte
    Commented Aug 24, 2013 at 17:13
-3
I like the FreeScale MC33660. (http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MC33660)
"The 33660 is a serial link bus interface device designed to provide bi-directional half-duplex communication interfacing in automotive diagnostic applications. It is designed to interface between the vehicle’s on-board microcontroller (5V) and systems off-board ( 12V ) the vehicle via the special ISO K line. "
  • \$\begingroup\$ The transceiver will most likely distort the signal's timing, and he would need 1 IC per channel. \$\endgroup\$
    – Johan.A
    Commented Aug 21, 2013 at 7:24
  • \$\begingroup\$ So make sure to get a 'level shifter' that doesn't distort the signal. \$\endgroup\$ Commented Aug 21, 2013 at 14:25
  • \$\begingroup\$ Johan, so, the decision criteria for selecting a level shifter is that it not distort the signal, yes? Can you clarify why you think it is likely this level shifter distorts the signal? Particularly, more than other circuits described in this question? \$\endgroup\$ Commented Aug 21, 2013 at 18:08
  • \$\begingroup\$ For a logic analyzer you want as little and as simple components as possible between your signal and the logic analyzer. Anything more complex than a resistor divider may skew the signal. \$\endgroup\$
    – Johan.A
    Commented Aug 22, 2013 at 6:45
    \$\begingroup\$ @Johan.A Comments like that are no acceptable here, dont repeat that behavior. \$\endgroup\$
    – Kortuk
    Commented Aug 22, 2013 at 17:12
