Who can help me identify this transistor?
It came out of a Chinese micromotor power supply.
Text on top is "D1047 905".
https://www.dropbox.com/s/r0ib8ikionm7ctu/Photo%20Aug%2022%2C%2010%2055%2028%20AM%20%28HDR%29.jpg
Can I substitute it with other transistor?
Here is a datasheet for a 2SD1047, which will almost certainly be for this device.
Searching for "D1047 datasheet" finds a few more similar datasheets, it's a NPN power transistor. Certainly replaceable with a similar component from e.g. Farnell, Digikey, etc - they will have many options.
Of course, you can always order an exact replacement if you should wish.
  • \$\begingroup\$ Even the angled top of the plastic part of the tab is right... Yup, looks like it all right. \$\endgroup\$ Aug 22 '13 at 15:27
Pinout and spec sheet - NPN 140V, 12A
