I had purchased an ATMEGA 16 microcontroller and chaged its fuse bits settings and used internal caliberated RC clock with 1000000. Changes done in make file and F_CPU. But it do nothing.
Programme for LED Blinking
#define F_CPU 1000000UL
int main(void)
   DDRC=0xFF;
  while(1)
        PORTC=0xFF;
   _delay_ms(1000);
    PORTC=0x00;
    _delay_ms(1000);
At the same time the following programme works fine.Can somebody helps me out please its urgent.....Did I forgot something to do..... These problems are same while using external 16Mhz crystal. Programme for LED Glowing.
int main(void)
   DDRC=0xFF;
  while(1)
        PORTC=0xFF;
I am surprised that this compiles at all, as you are missing two #include:
#include <avr/io.h>
#include <util/delay.h>
int main(void)
   DDRC=0xFF;
  while(1)
        PORTC=0xFF;
   _delay_ms(1000);
    PORTC=0x00;
    _delay_ms(1000);
Note that F_CPU must be defined before the #include - that can be done in code as shown or in the makefile.
| improve this answer | |
