I'm working on a Microblaze-based system. I'm using FSL to shuttle data directly from an AC'97 controller core to my custom DSP core. The FSL buses are clocked at the 125MHz system clock. The DSP components have been designed with a 48kHz clock in mind (the codec sampling rate).
How do I go about clocking the samples through the DSP components at 48kHz?
FSL bus is essentially a FIFO, that signals when data is available for the slave to read. Through some experimentation, I'm seeing samples arrive at approximately 48 kHz (I was using a timer interrupt in the uBlaze to monitor this, hence the "approximately"). Is there any way I can generate a sane "clock" from this fact, and also allow XST to understand the timing requirements of what I'm doing?
    \$\begingroup\$ While clock enable is clearly the answer, most DSP algorithms at audio rate use sequential implementations of dot-product type operations, such that you actually need a clock many times the sample rate. \$\endgroup\$ Sep 2, 2013 at 16:52
  • \$\begingroup\$ Yep, at some point I figured I would have to take advantage of all those "extra clocks" not being used. So far, my algorithms have all been able to complete within one clock cycle. Thanks for confirming that suspicion! \$\endgroup\$ Sep 2, 2013 at 18:53
  • \$\begingroup\$ That one sentence really opened up my eyes to how more complex algorithms would be implemented. Thank you so much! \$\endgroup\$ Sep 2, 2013 at 18:56
Clock the DSP at 125MHz, but apply a "clock enable" signal to it that is pulsed active every 2604 clocks @ 125MHz; that will give you a DSP rate of 48,003Hz - well within the error you can expect on the original clock.
  • \$\begingroup\$ Like this? \$\endgroup\$ Aug 29, 2013 at 15:27
  • \$\begingroup\$ This doesn't really address the synchronization with the FSL FIFOs though. And the fact that I get a pulse every sample via the FSL_S_Exists line. \$\endgroup\$ Aug 29, 2013 at 15:37
  • \$\begingroup\$ Yes, like that. \$\endgroup\$
    – markt
    Aug 30, 2013 at 6:04
    \$\begingroup\$ If you want to synchronise your DSP's operation to your codec, then maybe derive a CE signal for the DSP off the codec's control signals instead of using a divider. \$\endgroup\$
    – markt
    Aug 30, 2013 at 6:07
As markt suggested, the solution is clock gating.
I have placed all of my project code on GitHub. You can see where I handle the FSL bus transactions here.
The entire design remains in the 125 MHz system clock domain, but a clock enable signal is used throughout the DSPs. Since this happens every sample, I named this signal samp_ena. Sample usage:
process (sys_clk) is
begin
   if rising_edge(sys_clk) then
      if samp_ena = '1' then
         -- Register new sample
      end if;
   end if;
end process;
I'm generating this samp_ena signal in my FSL transaction state machine. An example:
case fsl_state is
   when FSL_SREAD =>
      if (FSL_S_Exists = '1') then
         new_sample <= FS_S_Data;
         samp_ena <= '1';
         fsl_state <= FSL_MWRITE;
      end if;
end case;
-- Pulse samp_ena for one sys_clk only
if (samp_ena = '1') then
   samp_ena <= '0';
end if;
