This question already has an answer here:
I have to design a board with a package case called MSOP-16
It has a large ground pad underneath the IC. What are good methods for soldering this pad by hand with a soldering iron?
Since it is a prototype, I was thinking to put a large enough via inside of the pad and to heat the via and drop solder through it from the other side after the outer pins have already been soldered.
marked as duplicate by Leon Heller, Anindo Ghosh, Matt Young, Dave Tweed, Nick Alexeev Aug 29 '13 at 17:05
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
  • \$\begingroup\$ Yes, I did not see that question. Thanks for showing it. \$\endgroup\$ – EwokNightmares Aug 29 '13 at 13:27
You can also use the Sparkfun "reflow skillet" method.
