I am trying to debug LPC1768 using a JTAG debugger and openOCD(version 0.7.0). My os is Win7 .
I'm connetced to the openOCD via telnet(port 4444) commands like halt, flash info, resume etc do work peoperly.
Now when I do
flash erase_sector 0 0 0
I get the follow reply
erased sectors 0 through 0 on flash bank 0 in 5.705326s
then I do
mdw 0 7
and it returns
0x00000000: 10001ffc 1fff0081 ffffffff ffffffff ffffffff ffffffff ffffffff
What are those first two words? Should it not be all ffffffff?
Snapshot CMD
UPDATE
flash write_bank too has no effect on flash.
I then uploaded the same binary using H-JTAG and it got programmed. So that means my chip isn't bricked!
content of my openocd cfg file
interface parport
gdb_port 3333
gdb_memory_map enable
gdb_flash_program enable
source [find board/mcb1700.cfg]
contents of mcb1700.cfg
# Keil MCB1700 PCB with 1768
# Reset init script sets it to 100MHz
set CCLK 100000
source [find target/lpc1768.cfg]
interface parport
parport_port 0x378
parport_cable wiggler
global MCB1700_CCLK
set MCB1700_CCLK $CCLK
$_TARGETNAME configure -event reset-start {
    # Start *real slow* as we do not know the
    # state the boot rom left the clock in
    adapter_khz 100
# Set up 100MHz clock to CPU
$_TARGETNAME configure -event reset-init {
    # PLL0CON: Disable PLL
    mww 0x400FC080 0x00000000
    # PLLFEED
    mww 0x400FC08C 0x000000AA
    # PLLFEED
    mww 0x400FC08C 0x00000055
    # CCLK=PLL/4 (=100 MHz)
    mww 0x400FC104 0x00000003
    # CLKSRCSEL: Clock source = internal RC oscillator
    mww 0x400FC10C 0x00000000
    # PLL0CFG: M=50,N=1 -> PLL=400 MHz
    mww 0x400FC084 0x00000031
    # PLLFEED
    # PLLFEED
    # PLL0CON: Enable PLL
    mww 0x400FC080 0x00000001
    # PLLFEED
    # PLLFEED
    sleep 50
    # PLL0CON: Connect PLL
    mww 0x400FC080 0x00000003
    # PLLFEED
    # PLLFEED
    # Dividing CPU clock by 8 should be pretty conservative
    global MCB1700_CCLK
    adapter_khz [expr $MCB1700_CCLK / 8]
    # Do not remap 0x0000-0x0020 to anything but the flash (i.e. select
    # "User Flash Mode" where interrupt vectors are _not_ remapped,
    # and reside in flash instead).
    # See Table 612. Memory Mapping Control register (MEMMAP - 0x400F C040) bit description
    # Bit Symbol Value Description Reset
    # value
    # 0 MAP Memory map control. 0
    # 0 Boot mode. A portion of the Boot ROM is mapped to address 0.
    # 1 User mode. The on-chip Flash memory is mapped to address 0.
    # 31:1 - Reserved. The value read from a reserved bit is not defined. NA
    # http://ics.nxp.com/support/documents/microcontrollers/?scope=LPC1768&type=user
    mww 0x400FC040 0x01
contents of lpc1768.cfg
# NXP LPC1768 Cortex-M3 with 512kB Flash and 32kB+32kB Local On-Chip SRAM,
set CHIPNAME lpc1768
set CPUTAPID 0x4ba00477
set CPURAMSIZE 0x8000
set CPUROMSIZE 0x80000
# After reset the chip is clocked by the ~4MHz internal RC oscillator.
# When board-specific code (reset-init handler or device firmware)
# configures another oscillator and/or PLL0, set CCLK to match; if
# you don't, then flash erase and write operations may misbehave.
# (The ROM code doing those updates cares about core clock speed...)
# CCLK is the core clock frequency in KHz
set CCLK 4000
#Include the main configuration file.
source [find target/lpc17xx.cfg];
  • \$\begingroup\$ Try flash erase_sector 0 0 last -< erase the whole first flash bank. \$\endgroup\$
    – Vorac
    Aug 29, 2013 at 14:37
  • \$\begingroup\$ I tried that as well. No effect! \$\endgroup\$
    – vyi
  • \$\begingroup\$ Another idea. Try flashing the chip with program or flash write_image and see if those succeed. If there are problems again, consider hardware erase of the whole chip, if available. The chip might be locked for some reason. \$\endgroup\$
    – Vorac
    Aug 29, 2013 at 14:40
  • \$\begingroup\$ If you are having problems with the JTAG hardware (which sounds unlikely), you can try using the ftdi driver in place of the fd2232 \$\endgroup\$
    – Vorac
    Aug 29, 2013 at 14:49
  • \$\begingroup\$ @Vorac My JTAG is a LTP based wiggler clone. And I highly suspect its frequency settings. I'm trying to lower the frequency now! \$\endgroup\$
    – vyi
    Aug 29, 2013 at 14:51
You forgot:
reset init
Background: The LPC1768 maps a ROM bootloader by default at addess 0x0. The reset init handler in recent OpenOCD version does the remapping to flash memory.
  • \$\begingroup\$ So I should be doing reset init followed by erase followed by flash followed by gdb debugging ? \$\endgroup\$
    – vyi
    Aug 29, 2013 at 20:04
  • \$\begingroup\$ I'm getting this[docs.google.com/file/d/0B_OcX1Wr8s5WUzhUY0QwdUpfUjQ/… Error! Also check the mcb1700.cfg file content in update! seems some mww error. but where? \$\endgroup\$
    – vyi
    Aug 29, 2013 at 20:09
  • \$\begingroup\$ Make sure the SRST line is connected and use reset_config srst_only separate \$\endgroup\$
    – Turbo J
    Aug 29, 2013 at 20:22
  • \$\begingroup\$ Also, looks a bit like your JTAG speed is too high. \$\endgroup\$
    – Turbo J
    Aug 29, 2013 at 20:28
  • \$\begingroup\$ The JTAG-Adapter works well with H-JTAG which doesn't provides GDB debug capability. reset_config srst_only seperate gives this(docs.google.com/file/d/0B_OcX1Wr8s5WYVp1UGVVNzA5MTA/…) output. What JTAG speed should I use here? \$\endgroup\$
    – vyi
    Aug 29, 2013 at 20:31
