10
As an absolute layperson in electronics I just found out that an LED only lights up when connected like in figure 1 but not when connected like in figure 2. And I just don't get why?
I know an LED is a diode and current can only move through it in one direction, but that's the case in both constructions. I don't see a difference in both constructions.
So why does it obviously make a difference?
figure 1 (battery not depicted): LED is on figure 2 (battery not depicted): LED is off
In the second arrangement, both legs of the LED are on the same horizontal row - In breadboards, each set of 5 holes on either side of the board is shorted together.
In other words, your LED's legs are shorted together, no current will flow through it.
See this image of how a breadboard's holes are typically connected internally:
Image (source)
The red thin lines indicate internal connections between the respective holes.
For a more detailed discussion on breadboards see this answer.
Specific to the Fritzing software the images in the question seem to be made in:
Note that as soon as any lead of a component is inserted into a hole in the on-screen breadboard, all the holes that are internally connected get a green indication - That shows that those holes are essentially electrically connected to the occupied hole.
  • \$\begingroup\$ Thanks Anindo, that makes perfect sense. I didn't think about the fact that the legs are shorted together. \$\endgroup\$ Aug 30 '13 at 7:03
What you have to understand is that horizontally placed objects on a breadboard does not mean you're connecting them in series. Rows on a breadboard implies that that's the direction of current. Placing an LED horizontally on a bread board is like connecting a wire from the positive to negative legs of an LED, it will short it out. Therefore, positioning LED's vertically on a breadboard removes this short.
TL;DR : always place electrical units in vertical progressions unless you want to simulate a parallel circuit.
  • 5
    \$\begingroup\$ I'm trying to figure out what value your answer added, exactly. \$\endgroup\$ Aug 30 '13 at 15:40
It's somehow clear in the second case that the LED is in parallel with a wire so the current prefers to move throgh the wire instead of the LED. In fact, the wire removes the LED.
