First time during my entire engineering career I have been to an emc lab last week. My design has failed to satisfy FCC requirements. The board uses a 25mhz clock and we have failed at 500mhz but I can also see other harmonics being high. It turns out a connector with an unshielded cable is acting as an antenna and failing us however i suspect the problem is deeper. I can probably shield the cable and pass however this feels like a band aid solution. How do I trace the deeper problem without accessing to a full blown lab. ( every day at the lab cost about 3k). I am specifically looking for troubleshoot advice of where to look and methods of verifying or tracing the problem without a lab but with a low end spectrum analyzer.
\$\begingroup\$ Lots of good stuff about debugging EMC here: emcesd.com \$\endgroup\$ – The Photon Sep 1 '13 at 15:55
\$\begingroup\$ More here, help choosing equipment. edn.com/electronics-blogs/4376432/The-EMC-Blog \$\endgroup\$ – Erik Friesen Sep 2 '13 at 1:34
You can do relative measurements with a spectrum analyzer. Without a properly set up calibrated test range, you won't be able to make absolute measurement, but you don't really need to either.
You do need to be very careful that all the measurements you take are repeatable. When I've done this, I've taped down the receiving antenna that feeds the spectrum analyzer under the table, taped down the feed wire to it, marked with tape exactly where on the table the unit under test goes, and taped down any cables that go to the unit that are necessary to test it.
Once you have a repeatable setup, take a bunch of readings as a baseline, and then write down or otherwise carefully record the results. Modern units have ways of getting data out and onto your PC where you can save it, but just a old fashioned picture of the analyzer screen can be good enough too.
Once you have a baseline, you can make modifications and see the relative results. Don't expect the changes to have exactly the same relative effect later on the calibrated test range, but if you are 3 dB over at a particular frequency and you knock down that peak by 15 dB, you'll be OK. Your measurements will be near field, but in practise that doesn't matter much. Figure at least 3 dB is slop, so you want to bring any offending peaks down by at least 3 dB more than the original test says they need to be. 6 dB is a lot better. Chances are you can knock most of the peaks down by 15 dB or more with just a few basic modifications.
The best way to avoid EMI problems is to design for that in the first place. The single most important thing you can do is to have a good grounding strategy. A pervasive ground plane is good, but not if every little connection punches down to the ground plane. Then you have a center-fed patch antenna. Keep local high frequency loop currents local and off the main ground plane.
Another obvious thing to do is to put small capacitors to the main ground plane on all signals that go off board, right where they leave the board. Sometimes this is not possible due to the nature of the signals or the isolation required, but even a few 10s of pF can make a big difference. Many signals can tolerate that since most cables will expose them to more than that anyway.
Radiated noise tends to be common mode, so baluns on differential signals can help a lot. Most ethernet transformers, for example, come with baluns on the network-side pairs for that reason. In that case you don't want to use caps to ground due to the isolation requirements, but the baluns built into the transformers usually do a good enough job anyway.
To test whether emissions are escaping as common mode signals on a cable, clamp a ferrite around the cable and see if that reduces the peak. If it does, you have a common mode emission problem on that cable.
Whole books could be written about this, so there is too much to get into here. Go find someone that has been thru this before to help you this time. Be prepared that the answer may mean a re-layouot with RF emissions considered. You can only bandaid a bad layout so far.
3\$\begingroup\$ Whoever downvoted this: It is useful to explain what you think is wrong, misleading, badly worded, etc. I believe what I wrote is correct and useful advice, having done these things myself on a number of projects. Without explanation, there is no way to know what to fix, or whether the misconception is on your end. \$\endgroup\$ – Olin Lathrop Sep 1 '13 at 17:14
First off you should find out if the interference is common mode or differential model. It's probably common mode at those frequencies. I'd play with various parts of the circuit, by slowing the edges of the fast switching waveform down until you see a change in the output of the spectrum.you could sniff around the circuit with a scope, looking for rininging at that frequency. Understanding where the interference is coming from, can often point towards a solution. It's critical to understand the interference mechanisms to figure out if it's technically / economically fixable.
