I'm using a solar panel to power an Arduino + a LiPo battery charger. I'd like to increase the amount of current at the same voltage, so would like to wire up a second solar panel in parallel to the current one.
The panels are slightly different:
One is a 6V; the other an 8V.
Assuming my charger can take the voltage (it can), is there anything special I need to do to wire these in parallel? Do I need blocking diodes on both?
EDIT: I'm reopening this because putting these panels in parallel did not work. I'm certain of the wiring, and each individual panel works fine, but putting them together drops the voltage down to <1V. I'm assuming the voltage imbalance is creating some kind of issue. Is this something that can be addressed with additional (simple) circuitry, or should I just buy another matching panel?
  • \$\begingroup\$ I disagree. The circuit is quite discrete - two solar panels, of specified parameters, wired together in parallel, providing power to a LiPo charger. What additional detail would you like? \$\endgroup\$ – kolosy Sep 9 '13 at 3:48
Putting the two dissimilar panes in parallel is not a good idea. Mostly, the higher voltage panel will deliver most of the current and the low voltage panel does little.
If the two panels have similar current ratings but different voltage rating, you can put them in series to get the sum of the voltages at the single current rating. Then use a switching power supply to buck the higher voltage down to what you want. For maximum voltages under 30 V, it's actually not hard to make your own buck converter. There are many off the shelf chips that you only need to add a inductor, diode, and a few other parts too. You can even make your own with a microcontroller if you want to learn more about buck converters.
  • \$\begingroup\$ Actually, since one is 310mA Isc and the other 500mA Iopt, putting them in series is also not a good idea. They are much better matched in voltage than in current. \$\endgroup\$ – Bobbi Bennett Sep 9 '13 at 15:24
  • \$\begingroup\$ @Bobbi: Like I said "If the two panels have similar current ratings ..." \$\endgroup\$ – Olin Lathrop Sep 9 '13 at 15:38
  • \$\begingroup\$ These are not exactly dissimilar panels, though, in the context of your first statement. They actually should have very similar Voc and Vopt. \$\endgroup\$ – Bobbi Bennett Sep 9 '13 at 16:08
    \$\begingroup\$ In the situation you describe I see a couple of issues. First, a LiPo charger needs very stable voltages. We've all seen what can happen to Li batteries when not treated well. Second, when you hook two panels in parallel like described, one will likely discharge into the other. You are better off with one panel that can handle the whole load. \$\endgroup\$ – SDsolar Feb 26 '17 at 2:13
  • \$\begingroup\$ that's very close to my concern I described here as well: electronics.stackexchange.com/questions/387164/… \$\endgroup\$ – Tagar Jul 23 '18 at 20:04
protected by Community Sep 3 '13 at 1:52
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
