I am trying to program a PIC10f202 using the XC8 compiler to compare the value of a timer to a variable which will be a function of a look-up table. Here is a sample code :
#include <xc.h>
#pragma config MCLRE = OFF
#pragma config CP = OFF
#pragma config WDTE = OFF
Init(void){
TRIS=0;
GPIO=0;
TMR0 = 0;
OPTION = 0b00000011;
const unsigned char LUT[250] = {
0b00000000, 0b00000001, 0b00000001, 0b00000001, 0b00000001,
0b00000001, 0b00000001, 0b00000001, 0b00000001, 0b00000001,
0b00000001, 0b00000001, 0b00000001, 0b00000010, 0b00000010,
0b00000010, 0b00000010, 0b00000010, 0b00000010, 0b00000011,
0b00000011, 0b00000011, 0b00000011, 0b00000011, 0b00000100,
0b00000100, 0b00000100, 0b00000101, 0b00000101, 0b00000101,
0b00000110, 0b00000110, 0b00000110, 0b00000111, 0b00000111,
0b00001000, 0b00001000, 0b00001001, 0b00001001, 0b00001010,
0b00001010, 0b00001011, 0b00001100, 0b00001100, 0b00001101,
0b00001101, 0b00001110, 0b00001111, 0b00010000, 0b00010000,
0b00010001, 0b00010010, 0b00010011, 0b00010011, 0b00010100,
0b00010101, 0b00010110, 0b00010111, 0b00011000, 0b00011001,
0b00011010, 0b00011011, 0b00011100, 0b00011101, 0b00011110,
0b00011111, 0b00100000, 0b00100001, 0b00100010, 0b00100100,
0b00100101, 0b00100110, 0b00100111, 0b00101001, 0b00101010,
0b00101011, 0b00101100, 0b00101110, 0b00101111, 0b00110000,
0b00110010, 0b00110011, 0b00110101, 0b00110110, 0b00111000,
0b00111001, 0b00111011, 0b00111100, 0b00111110, 0b00111111,
0b01000001, 0b01000010, 0b01000100, 0b01000110, 0b01000111,
0b01001001, 0b01001011, 0b01001100, 0b01001110, 0b01010000,
0b01010001, 0b01010011, 0b01010101, 0b01010111, 0b01011000,
0b01011010, 0b01011100, 0b01011110, 0b01100000, 0b01100001,
0b01100011, 0b01100101, 0b01100111, 0b01101001, 0b01101010,
0b01101100, 0b01101110, 0b01110000, 0b01110010, 0b01110100,
0b01110110, 0b01111000, 0b01111001, 0b01111011, 0b01111101,
0b01111111, 0b10000001, 0b10000011, 0b10000101, 0b10000111,
0b10001000, 0b10001010, 0b10001100, 0b10001110, 0b10010000,
0b10010010, 0b10010100, 0b10010110, 0b10010111, 0b10011001,
0b10011011, 0b10011101, 0b10011111, 0b10100000, 0b10100010,
0b10100100, 0b10100110, 0b10101000, 0b10101001, 0b10101011,
0b10101101, 0b10101111, 0b10110000, 0b10110010, 0b10110100,
0b10110101, 0b10110111, 0b10111001, 0b10111010, 0b10111100,
0b10111110, 0b10111111, 0b11000001, 0b11000010, 0b11000100,
0b11000101, 0b11000111, 0b11001000, 0b11001010, 0b11001011,
0b11001101, 0b11001110, 0b11010000, 0b11010001, 0b11010010,
0b11010100, 0b11010101, 0b11010110, 0b11010111, 0b11011001,
0b11011010, 0b11011011, 0b11011100, 0b11011110, 0b11011111,
0b11100000, 0b11100001, 0b11100010, 0b11100011, 0b11100100,
0b11100101, 0b11100110, 0b11100111, 0b11101000, 0b11101001,
0b11101010, 0b11101011, 0b11101100, 0b11101101, 0b11101101,
0b11101110, 0b11101111, 0b11110000, 0b11110000, 0b11110001,
0b11110010, 0b11110011, 0b11110011, 0b11110100, 0b11110100,
0b11110101, 0b11110110, 0b11110110, 0b11110111, 0b11110111,
0b11111000, 0b11111000, 0b11111001, 0b11111001, 0b11111010,
0b11111010, 0b11111010, 0b11111011, 0b11111011, 0b11111011,
0b11111100, 0b11111100, 0b11111100, 0b11111101, 0b11111101,
0b11111101, 0b11111101, 0b11111101, 0b11111110, 0b11111110,
0b11111110, 0b11111110, 0b11111110, 0b11111110, 0b11111111};
unsigned char cnt1=0;
void main(){
Init();
for(;;){
cnt1 = LUT[100];
while(TMR0 > 100){
GPIO=0b00000001;
GPIO=0b00000000;
The look-up table is 250 characters because this is the maximum size that was allowed by the compiler before it gave me an error "Can't find x0FF words (x0ff withtotal) for psect "stringtext1" in class "Entry"". The code compiles fine, with MPLAB X stating 55% flash memory usage and 0% RAM usage. If I change the "while" condition to this :
while(TMR0 > cnt1)
The compiler will again give me a similar error : "Can't find x0FA words (x0fa withtotal) for psect "stringtext1" in class "Entry"". I understand the compiler can't find enough memory to write the code, but I don't see how 45% free space is not enough for this task. Also, why am I not able to create an array with 255 elements? The PIC10f202 has 512 words of memory, it should be possible.
Why is the compiler giving those errors?
