I would like to turn on a IRF510 MOSFET using a logical "1" @ 3.3V.
According to it's datasheet, the "Gate to Threshold Voltage" is 2-4V... Does that mean I'll be able to completely turn on the MOSFET using a logical "1" @ 3.3V?
Here is the datasheet for more info: https://www.jameco.com/Jameco/Products/ProdDS/209234FSC.pdf
Read your own question. The answer is obvious since it is embodied in the question.
You said yourself the gate threshold voltage is 2-4 V according to the datasheet. So how can 3.3 V on the gate possibly guarantee that the device is on? Clearly 3.3 V is less than 4 V.
You should also look more closely at what gate threshold really means. Note that it defines "gate threshold" as the gate voltage at which there will be 250 µA of drain current. That's unlikely to be a useful amount of current in your application, and is certainly not in any way the fully on state of the MOSFET.
Gate threshold is not a useful parameter if you want to turn the FET fully on. It tells you where it starts to turn on, not what it takes to turn it on fully, or full enough for your application.
The drain to source on-resistance is much more relevant, just a few lines in the datasheet below the threshold voltage. That is specified as 540 mΩ, but at 10 V on the gate. In other words, this FET is intended for 10 V gate drive to really want to turn it on. They aren't making any promises what happens between the threshold voltage and 10 V.
If you want to drive a FET with only 3.3 V on the gate, you have to get one specified for that. For example, the IRLML2502 is characterized at low gate voltages. The datasheet promises the Rdson will be 80 mΩ or less at 2.5 V on the gate, and 45 mΩ or less at 4.5 V. So one of those can be usefully driven from 3.3 V. In that case you know it won't exceed 80 mΩ and can support up to 3.6 A.
  • \$\begingroup\$ I guess I misunderstood the meaning of the phrase gate threshold... Thanks for the help. \$\endgroup\$
    – Soviero
    Sep 4 '13 at 1:41
    \$\begingroup\$ The IRLML2502 came up as a SMD when I looked, some TO-220 packages (with legs you can plug in a breadboard) are IRLB8743PBF, IRLB8721PBF, IRLB3036PBF, IRLB3034PBF, and HFP50N06. These all have a gate threshold of about 1.8-2.35V. \$\endgroup\$ Nov 7 '15 at 6:52
  • \$\begingroup\$ @wordsforthewise: thank you, I've just been looking for sturdy high-current logic-drivable MOSFETs to switch some things in my car. However, these devices are also have max. current rated at 10 V G-S. \$\endgroup\$ Jan 24 '16 at 16:43
  • \$\begingroup\$ Thank you for that tip, @wordsforthewise - IRLB8743PBF is a much better choice and 5 of them are available via slow boat for $2.55 and free shipping: ebay.com/itm/… \$\endgroup\$
    – SDsolar
    Sep 23 '17 at 20:24
